Hybrid to cyclocross
  • This topic has 10 replies, 5 voices, and was last updated 9 years ago by shewy.
  • #27784
    shewy
    How easy is it to convert my hybrid into a cyclocross? Got a Boardman team hybrid, 2×10 tiagra with hydraulic Shimano br-m477 calipers.
    The bars i think would be easy as would the tyres as current are 32mm, not sure about the sti though.
  • #905149
    shewy
    So in the end I’ve ordered
    So in the end I’ve ordered tiagra sti, and Sora mechanical discs, for £150, will keep the hydraulic just in case
    #905147
    shewy
    I was looking for at £120 for
    I was looking for at £120 for sti and £70 for callipers, so £170 all in, the hydraulic sti’s are around £280, but may be worth it if they fit the m477 brakes
    #905145
    kil0ran
    TypeVertigo wrote:
    If you can buy the hydraulic STI levers, they should work fine with your brake calipers as is. I believe the relevant part number is the ST-RS405 – it’s basically the ST-RS505 STI lever with one detent removed in the rear gear shifting mechanism. That will work fine with your Tiagra 4700 mechs
    This. Shouldn’t need anything else. Take the opportunity to replace your shifter cables and you’re good to go.
    You’d probably miss hydraulics if you drop down to mechanical and as you also need the STIs you’d just as well go with hydro. The alternative is going to be more expensive – £100 used for the mechanical levers plus around £125 for a set of hybrid cable-actuated hydros like the Juin Tech R1s
    Oh, one more thing – you’ll maybe need a bleed kit because you’ll be opening the system to do the swap.
    #905143
    shewy wrote:
    shewy wrote:
    Having a look the back derailleur has 4700 stamped on it, so looks like that. Want drops so to winter train in a semi road position as got a 100 mile sportif coming up in March
    can get that position on flats and I’ve done a 100 miler on a flat bar too.
    Just curious why you thought it necessary.
    #905141
    TypeVertigo
    #905139
    shewy
    #905137
    kil0ran
    Current generation Tiagra
    Current generation Tiagra 4700 has a different pull ratio to 4600 and earlier (its now the same as the 11-speed groups) so you need to know what generation your derailleurs are.
    #905135
    Why do you think you need to
    Why do you think you need to swap to drops for CX?
    #905133
    shewy
    Yeah was thinking as it’s
    Yeah was thinking as it’s 2×10 tiagra fitting 2×10 tiagra road sti and then changing the brake callipers to Sora mechanical disc, or cx77.
    #905131
    CXR94Di2
    It’s all to do with the pull
    It’s all to do with the pull ratio on the new levers and your current derailleurs. I suspect they are different, so careful selection of sti levers or replace levers and derailleurs together.
