End caps with long tongue
  • This topic has 4 replies, 4 voices, and was last updated 9 years ago by AfterPeak.
  • #27778
    AfterPeak
    Hi
    Sorry if this has been asked before but I brought a groupset (6800) and there are two end caps with short tongues (which I know go into the shifters) but there was also 3 end caps with long tongues supplied. Where do these go? I can imagine one goes into the barrel adjuster on the rear mech but the other two I am not sure about. Are these for where the gear cables go into the down tube or come out?
    Thanks
  • #905061
    AfterPeak
    Thanks for the help.
    I am still a little confused why I have three. There are two gear cables going into the frame from the shifters so I could use them for that. Front mech doesnt need one where it comes out so should I use the last one where the gear cable comes out of the frame at the rear mech? or where the cable goes into the barrel adjuster?
    Alternatively should I use them for the brake internal cables?
    #905059
    Bob's Bikes
    As hennahairgel has said but
    As hennahairgel has said but also as you have said some frames with internal routing still need an end cap on the outer cable as it goes into the frame (some dont) if unsure about your own (i’m assuming internal frame) use them, it’s not costing you anything but not using them and losing gear shifting as the outer sleve of the outer cable gets pushed up/the coiled part enters the frame will ruin your ride and take time/money to put right.
    #905057
    hennahairgel
    They’re for external cable
    They’re for external cable stops
    #905055
    dottigirl
    Check the width – some will
    Check the width – some will be for gears, some may be for brakes?
