- This topic has 5 replies, 5 voices, and was last updated 8 years, 11 months ago by .
Hi All,
As the weathers turned I’ve found myself on my winter bike more and more. I’ve been prepping for a few hours spent doing some annual maintenance tasks on the best bike (my wifes away next weekend so I can actually work inside in the warm rather than being banished into the garden 🙂 ).
My best bike has around 12000km on it now; it’s rather hard to describe – but I think I should probably be replacing the BB (Pressfit 86 (86.5x41mm)) as it feels occasionally like it’s not spinning smoothly. I’ve heard pressfit BB’s described as a commodity item, which people replace regularly.
The one’s I’ve seen online seem to be around £45 (http://www.wiggle.co.uk/shimano-sm-bb92-41b-pressfit-road-bottom-bracket/) which is more than I thought they’d be.
So, first question:
– Are all pressfit BB’s created equal? Should I just buy the standard Shimano one in a like-for-like replacement? Or are aftermarket ones worth looking at (bike has 2016 Ultegra Di2 if that makes any difference). It’s an expensive bike so I haven’t tended to scrimp on components.
– What tools do I need to do this myself? I already have one of these (https://www.parktool.com/product/bottom-bracket-tool-bbt-9) as I needed one to swap disk brake rotors around. I’m guessing I need a bearing press (or to create one myself as per the youtube videos), some loctite? Anything else?
Second question is around chains. I use dry lube on my best bike, so I need to strip off all the factory grease/oil from the replacement chain before waxing it. In the past I’ve used a bio-degreaser for this, but its always felt like a bit of a faff. Can I just bathe it in white spirit for a few hours, a couple of times? Anyone got any hints for stripping down a new chain?
Cheers,
