- This topic has 5 replies, 5 voices, and was last updated 8 years, 8 months ago by .
going to service the hubs on my summer wheels soon, the front is sounding a bit rough and is the through axle type with adapters to make it normal QR type, so will likely have sealed bearings in there somewhere, and the back is just old fashioned cup n cone.
the back is no problem, but a little unsure how to do the front. I’ve tried prising the plastic/rubber sheild off one side but it just looks lke i’m going to butcher it, so I left it. I’ve searched online and must have found 10 videos about hubs NOT LIKE mine, but not one video with the same hubs as mine. anyway, on one of them it shows you can just remove the dust seal from the bearing, de-grease, clean and dry them and the re-pack with grease and re-assemble. is this likely to work if the hubs are at the stage where they are making a noise already? or would I be better off replacing the bearings completely?
how much do bike shops charge for this, seems you need a few tools which I don’t have
