Creaking hell
  • This topic has 26 replies, 14 voices, and was last updated 9 years ago by Wilderbeest.
  • #27695
    Big Jay
    A creak down under is doing my nut in. BB is fine, pedals replaced, stem and seat post greased. It only appears in a very rhythmical grunt when going up hills (>4% +), stops when I free wheel and temporarily stops if I change up or down on the climb.
    Please help this frustrated man.
Viewing 15 replies - 1 through 15 (of 26 total)
  • #903495
    Wilderbeest
    Worth pointing out that I had
    Worth pointing out that I had to buy a second bike and swap out parts one at a time to work out what the problem was….
    #903493
    Wilderbeest
    I had same problem…creaking
    I had same problem…creaking when under pressure.
    left hand crank. Splines creaked when going uphill.
    #903491
    The _Kaner
    There’s only one way to
    There’s only one way to eliminate this untraceable noise. N+1.
    #903489
    Big Jay
    Hey thanks for all the  input
    Hey thanks for all the  input everyone, so far I’ve greased the pedals, tightened crank bolts, cleaned and greased the thru axles and cleaned the chain thoroughly and changed the lube from dry wax to wet lube. Took it for a 25k, 600m elevated ride and it was slick. I’m touching wood seems ok but will be out for longer tomorrow to see.
    heres hoping
    #903487
    zzk
    #903485
    zzk
    Need to be pragmatic:
    Eliminate cleats: get your trainers on and go ride up a hill. No squeak, not cleats
    Tighten and grease chain ring bolts: easy done
    Check chain for wear, clean and lube and try
    Remove chainset: check BB for friction/ smooth running, lube surfaces, clean axle and tighten to ensure no play. Is it your shoe rubbing the crank arm
    Front mech: position correct, no chain rub
    Cassette: remove clean and make sure tight with no play
    Headset: check on climbs, does it occur when just out the saddle or even when seated and hands rested on the tops
    Wheels: check QRs/ axles for wear/ spoke tensions etc
    Grease everything and anything. There was a good “creak” solving video on youtube sometime back, might be worth looking out.
    My experience is that riding with a friend can help localising the problem. Even better is if you can reproduce the sounds on a turbo trainer you can save yourself a lot of time and noisy rides. Good luck. There will be a solution, but can take a while to cure.
    #903483
    zzk
    #903481
    zzk
    #903479
    pwake
    If you’re convinced it’s in
    If you’re convinced it’s in the BB/crank area, then you’re probably right. You orginally said the BB was fine, but you’re dealing with a press-fit BB here, one of the worst ‘innovations’ of recent years. I recently had a similar experience with a BB386 EVO and changed out for a Wheels Manufacturing threaded replacement; no more creaks.
    Not saying this is the case here, but maybe.
    #903477
    nniff
    Tighten up the rear QR. If it
    Tighten up the rear QR. If it’s a Ti one, get a steel one, grease it and do it up tight.   I had a problem – wrongly diagnosed as spoke tension – not that.  Changed the skewers to Hope from Ti Planet X and the problem went.
    #903475
    Big Jay
    RMurphy195 wrote:
    I had this a couple ofyears ago on a fairly-new bike equipped with Mavic Aksium disc wheels. Turned out to be the hub on the rear wheel is made of of a number of parts – 3 I think I was told – that are bonded together. And the bonding had failed on the rear hub. Replaced under warranty, no problem since (so far!)
    Deatils in these links
    https://forum.cyclinguk.org/viewtopic.php?f=18&t=105798&p=1009113&hilit=creak#p1009113
    https://forum.cyclinguk.org/viewtopic.php?f=1&t=104561&p=995118&hilit=creak#p995118
    thanks I’ll get the LBS to check the hub, not letting me loose on them
    #903473
    Big Jay
    simonmb wrote:
    Big Jay wrote:
    simonmb wrote:
    I had something similar. Checked everything and couldn’t clear it. Well. Hadn’t checked the rear dropout though, because that’s what. Tightened up the screw fixing it to the frame, job done.
    thanks I’m looking later, would that explain the noise easing off very temporarily when changing up or down gears?
    Could well do. the creaking disappeared each time i took pressure off the pedals. We’re a bit of a poor man’s CSI:road.cc here without even a body to dissect though.
    Let us know how it goes. We’re with you brother.
    haha! Thanks man, I will get to the bottom of this. I am convinced it’s in the BB / crank but currently working through the list
    #903471
    RMurphy195
    #903469
    simonmb
    #903467
    Big Jay
