- This topic has 8 replies, 4 voices, and was last updated 8 years, 11 months ago by .
Anyone had any issues with these?
On my 2nd pair & both have now had the same issue which is a bit difficult to explain.
Basically at the rear of the pedal there is a type of screw which seems to keep the back black bit where the adjustment screw is attached to the front. Both times this has come out & will not go back in which means that although you can engage the cleat & it stays in it’s not properly engaged & your foot is slightly loose.
Both pairs I’ve had have now done this which seems a strange. Either I’m unlucky or they just aren’t that great.
This happened to anyone else?
