Mechanical disc brake suggestions please
  • This topic has 24 replies, 19 voices, and was last updated 9 years ago by BarryBianchi.
  • #27578
    road
    Id love to get hydraulic / hybrid brakes but the cost is still too inhibitive for me.
    Ive currently got some Avid BB7 road on my CX/gravel bike, and whilst they are OK, theyre not great. I can set them up fine but find they need too much fiddling to keep them working properly, compared to my hydraulic brakes on MTB which only occasionally need the pads pushing back in to realign.
Viewing 15 replies - 1 through 15 (of 24 total)
  • #901191
    BarryBianchi
    I run BB7s on what was my
    I run BB7s on what was my commuter – work absolutley fine – fit and forget.  Cheap as chips relatively, and fuss-free.
    #901189
    TypeVertigo
    BBB wrote:
    I’ve been using a Klamper for a few months on my drop bar commuter (front only, sintered pads).
    Performance is on a pair with hydraulic systems.  Yes, it uses “outdated” tech and a single moving piston so in theory should be inferior to brakes like Spyre or hydros, but it’s not. I believe that almost all negative reviews come from people who never used one and make too many assumptions.
    Have you tried them on a really steep downhill descent? Curious to hear your thoughts.
    There is a popular 5-kilometer climb in my country with pitches approaching 35%, even 45% in some areas. Going back down is terrifying, even for MTB riders on hydraulics. That was probably the only time I wanted more braking power out of my Spyres, as it was shocking how quickly 54 km/h came and it felt like the Spyres were overheating.
    #901187
    BBB
    mike the bike wrote:
    BBB wrote:
    The best mechanical brake available is not Spyre but Paul Klamper. £200 though…….
    I saw these advertised in an American magazine just before I ordered my Spyres and a little internet digging revealed some very mixed reviews.  One guy reckoned that only a fool would spend so much on such outdated, heavy and mediocre kit.
    Although I know they are the old single-piston design, cost double the price of Spyres and have a look only a mother could love, I’ve never used them, neither do I know anyone who has, so I can’t comment on their efficiency.
    For the record I work on modern (overengineered) road bikes with both mechanical and hydraulic systems which gives me a good scale of reference.
    #901185
    TypeVertigo
    mattydubster wrote:
    I have Spyres and they’re great, very easy to set up and maintain. Although I know hydro’s would be much better, I would also realistically have to upgrade to 1 x 11, which would mean a new cassette, chain & possibly a chainring..
    Exactly my same concern. I’m running 10-speed 105 5700 myself.
    If you’re running 10-speed, you could save yourself the cost of replacing your cassette with Tiagra 4700 and its hydraulic brakes, but you’ll still have to swap out derailleurs and control levers…
    #901183
    mattydubster
    #901181
    TypeVertigo
    vegasfoster wrote:
    . . wrote:
    This is an interesting hybrid solution.   Anyone know how well they work?
    https://www.giant-bicycles.com/gb/conduct-hydraulic-disc-brake-upgrade-kit-flat-mount-version
    I test road a 2017 Contend and felt spot on to me with good modulation and stopping power.  I have not tried road reservoir levers though (e.g. rs505), so can’t directly compare.  They have expanded it to most of their road disc bikes for 2018 from a few last year, so Giant appears to be happy with them as well.  Long-term reliability would still be the outstanding question IMO.  That said, I would probably take it over mechanical brakes at that price, but may need to buy a Giant stem as well.
    I don’t think the Contend models use OverDrive2 stems…so far that seems to be the only “proprietary” bit about stems, steerer tubes, and headsets from Giant.
    I would love to see how the Conduct hardware connects to the stem faceplate, though.
    The only other complaint I hear about the Conduct system is its messy cable/hose routing, which seems to be just a consequence of the hybrid design. Then again, this is version 1 of the thing from Giant, so they might be able to clean it up in a future iteration if it’s still around by then.
    #901179
    TypeVertigo
    Where the Spyres are lacking is outright power, they just don’t have it and although they were an improvement on what went before, I don’t think they were as effective as a good rim brake set-up.
    I somewhat agree.
    Next to my Spyre-equipped TCX, I also ride a Dahon Vitesse folding bike with Shimano Alivio Trekking V-brakes. In terms of outright power, they’re very close, with the V-brakes actually having a minute edge…in the dry.
    The real value of the Spyres is in consistency and modulation though. Be very clumsy with the front V-brake and you can easily induce a tail whip on the Dahon. In the rain, the Alivio V-brakes take a bit of a prayer before they bite into the brake track sufficiently. Both are much less of a problem with the Spyres.
    #901177
    TypeVertigo
    +1 for TRP Spyres. As long as
    +1 for TRP Spyres. As long as your pads remain clean of oil or soapy water (the latter of which they’ll clear after a few successive hard stops), they’re as reliable as you’d want a cable-pull disc brake to be. Staying on top of their maintenance is very easy too, which goes a long way towards mitigating the need to keep them adjusted every so often when regularly ridden.
    For some reason, in my country, there’s a bias between the shiny silver Spyres and their OE Spyre-C counterparts with their matte black actuating stirrup arms. They’re the same exact caliper save for that cosmetic difference.
    I bought a pair of Spyre-Cs in the hopes of upgrading a future bike I plan to buy for my wife, but in the interim, I ran one of them on the rear of my TCX to test. No complaints. That said, if you’re still getting into trouble with well-adjusted Spyres, you might want to consider an upgrade to hydraulics or cable-actuated hydraulics.
    Regarding the Paul Klampers:
    I’ve read their supposed biggest advantage is just how beefy they are, because they’re machined and rigid as a rock. That way, more of the forces going into the caliper actually go into clamping down on the rotor and making you stop. I can certainly see the added beef they have compared to a Spyre unit (which explains their added weight), but I don’t quite understand why they couldn’t go with a similar twin-piston design as TRP did…methinks it’s down to tight clearances not allowing this. Their cost is considerable, too.
    #901175
    kil0ran
    That would appear to be an utter bargain at that price. Interested to see how they compare to Juin Tech & HY/RDs. Potentially better as you’re running less cable housing, just depends on lever feel and adjustability. Looks like you could still run crosstops. Hope have something similar but much more pricy.
    #901173
    RMurphy195
    I have the TRP Spyres on my
    I have the TRP Spyres on my tourer. Not as ultimately powerful as the hydraulic Hopes on my sons downhiller but plenty good enough once set up, and as someone else said when it rains, they just work – no “will they won’t they – ouch” as the rim rotates and water is swept off it, then suddenly biting.
    They are much more powerful than the cantilevers on my previous tourer once set up properly – get the instructions right, route the cable properly over the lever at the caliper end, with that bit at the correct angle to get maximum mechanical advantage and hey presto – you’re there! TRP video for these is very informative.
    Brake pads and the disc itself, as ever, can affect the performance, and sintered pads make a lot of noise in the dry I’ve found on the Aztec discs I am using.
    PS I’vedeliberately avoided hydraulics on the bike for simpilicity’s sake – I don’t want to ride off in a few years time and find a seal has gone leaving me with no brake!
    #901171
    sizbut
    I have two identical Kinesis
    I have two identical Kinesis ATRs except for the brakes: TRP Spyre and TRP Hy/Rd – the Hy/Rd are significantly better so another vote for the cable/hydraulic hybrid. As a heavy (very) rider its the first time I’ve had brakes that I can take to full locking with ease (when its required).
    I’ve actually migrated from BB5 to BB7 to the TRPs over the years. Going from BB7 to Sprye won’t really deliver any increase in full stopping power in my experience – the big benefit is that once the brakes are well setup on the Sprye they tend to stay that way a lot longer whereas I found the BB7s needed frequent readjusting to get them back to best performance. But the Hy/Rd will also deliver that benefit.
    #901169
    mike the bike
    #901167
    Crampy
    I currently run mtb BB7s on
    I currently run mtb BB7s on my CX with last gen (not the latest ones but the last gen before they were discontinued) Campag Centaur levers. There is a fair bit of pull, but they bite just fine and dont run out of pull before locking the wheel. The reason? They were cheap as chips compared to the road version at the time. I feel your pain with regards to the constant adjustments… I use my CX bike as a winter trainer / commuter and the inner adjustment wheel seizes up regularly on account of the road salt / crap that accululates there…
    If I were to upgrade I would go mech/hydro (Hy:Rds), but if I absolutely positively HAD to stay fully mechanical, TRP Spyres would be my choice.
    #901165
    bob_c
    I used to have BB5s which
    I used to have BB5s which were pretty dire and required constant adjustment. For the last year I have used Acor hydro/mechanical – same as juintech R1. They have been excellent – easy to set up and adjust, good modulation, hardly ever need adjusting etc. I think they were just over £100 for the pair. They’re cheaper, lighter and less clunky looking than Hy Rds.
    #901163
    Redvee
    I’ve got Hy:Rds on one bike
    I’ve got Hy:Rds on one bike and Juin Tech R1s on the other and both are brilliant brakes. I did have to bypass the cable guide on the chainstay with the R1s cause of the cable stop being outboard and leave the outer loosely zip-tied to the frame.
