- This topic has 8 replies, 5 voices, and was last updated 9 years, 3 months ago by .
Got one of these on my Cannondale CAAD 12 & haven’t touched it since I got the bike so figure it’s about time it I regreased the headset. However I’ve no experience at all of the integrated headset setup.
Is it just a case of loosening the top cap with a 6mm allen key, unscrewing the bolt inside with a 5mm key, removing the expander “bung” & then taking off the bars? Everything the same as a “normal” headset after that in terms of dropping the forks out, bearings etc?
The other thing I noticed when I was looking at the Cannondale manual online is that it states clearly that there should be no spacers above the stem but mine came with 2 above it!
