Garmin blue mount holder broken.
  • This topic has 6 replies, 5 voices, and was last updated 9 years ago by Leeroy_Silk.
  • #27489
    Leeroy_Silk
    Hi,
    Can anybody tell me whether the blue mount on the back of Garmins can be replaced? Mines on its last legs and I don’t really fancy forking out for a new unit just because of damaged piece of plastic.
    Cheers
  • #899667
    Leeroy_Silk
    The Gavalier wrote:
    I’ve used this:
    http://www.racewaredirect.co/shop/garmin-tab-repair/
    Glue it over the broken mount and away you go. Not bad for a tenner.
    Cheers ‘The Gavalier’.
    I’m definitely going to give that a go first. To all the rest who replied, thanks nice to know I still have options.
    #899665
    The Gavalier
    adamthekiwi wrote:
    I’ve just ordered the repair tab that The Gavalier mentioned… It looks like a fairly easy fix (but can report back if necessary).
    It couldn’t be easier, I’ve fitted 2 and both still going strong.
    #899663
    turnerjohn
    I got a second hand one for
    I got a second hand one for my old 800 off eBay for £20, no soldering needed but your need a tiny torx screwdriver and some patience !
    #899661
    adamthekiwi
    #899659
    The Gavalier
    I’ve used this:
    I’ve used this:
    Garmin Tab Repair
    #899657
    Inder
    Yes, you can replace the back
    Yes, you can replace the back. I think there is some soldering required as some of the wiring attaches to the rear cover, also a bit of silicon waterproofing required for the micro-usb port. There are companies on the internet who can do the repair (including Garmin) if it’s not something you want to tackle yourself….
