- This topic has 23 replies, 5 voices, and was last updated 9 years, 1 month ago by
trohos.
August 3, 2017 at 8:13 pm #27445
trohos
Hello.
It’s time to replace the headset in my bike but i have a query. I should replace the crown race in the fork or can avoid this job? The headset that the bike has already is a noname the new headset is FSA.
Thank you in advance.
trohos
I took the risk and hold the
I took the risk and hold the old crown race, seems to work fine. I will test it in the real world very soon.
Thank you all for your time!
I cannot believe that two
I cannot believe that two bike shops couldn’t remove that crown race! I think you should name and shame them – pathetic. The video link you posted is all you need to do to remove it – then find another (decent) bike shop to install the new race. However, before doing this I would ‘suck it and see’ – assemble with the current race and test ride.
CXR94Di2
A quick and easy way to fit a
A quick and easy way to fit a new race, is get a piece of plumbing pipe. Run a saw through the diameter to create a 2″ slot. Heat up the new race in the oven, drop it quickly onto tube upend forks and with plumbing tube bash it into place.Getting old race off , I’ve found a dremel to cut through most it then gently ease off
Jack Osbourne snr
trohos wrote:I made the test no site to site play to be honest i feel more play in old bearings. What worries my is that the bottom of the old bearing is slightly conical compared to the new. I mean the inner wall (colored in photo) is slightly lower from the seal and the outer wall compared to the FSA that all are in the same level.Ah, now I see.
If the overall height of the bearings are the same, that shouldn’t cause any problems. Just double check the seal isn’t rubbing on the base of the old crown race.
If there’s no rubbing, all the numbers on the bearings are the same and there’s no wobble with the new bearing with a load on it, then that race can stay put.
If you’re still not comfortable, you can either try the LBS again or go for the DIY method as in the video you posted. Definitely get the LBS to fit the new crown though. It’s a total pain doing it yourself without the right tool, which is expensive unless you have a fleet of bikes.
trohos
Thank you bro but i’m many many many Km far from you. The dimensions are the same 41.8x 30.5x 45 ° x45 ° http://shop.fullspeedahead.com/en/files/index/download/id/5dea8e4ef75ea284b90068e4d45d46a827/DaSy wrote:The bike shops you visited were being lazy I think. Those races are a pain to remove, as you have to work a blade or the like under it to get an initial small gap. Once you have it lifted by even a tiny amount, a Park Crown Race Puller will get it off.I grant you, it takes half an hour rather than 5 minutes, but it is easily do-able. If you live near Monmouth, I’d happily sort it out for you.
With regard to whether to leave the old one on, it depends on what the bearing angle of the bearing is and if that is the same as the crown race. If it isn’t then the bearing will be getting a point load on it that will inevitably reduce its service life.
trohos
I make the test not site to
Jack Osbourne snr
CXR94Di2 wrote:
CXR94Di2 wrote:Does the bearing sit nicely on the old race on the down tube? I would dry assembly and check for smooth movement without any catching. If that works disassemble and grease mating surfaces.LOL! I think you and I are perfectly aligned on this one!
Jack Osbourne snr
I’m not sure what you mean by
I’m not sure what you mean by a small log. I’m guessing at lip? The base of the old race looks slightly smaller than the new one. If so, its not a huge issue and you can ignore it.
Obviously, I can’t be 100% sure but looking at the photos, I think it’ll be fine to use the existing race.
One last test…
Slide the new lower bearing on and compare it to the look and feel of the old one when in position. Push down on the bearing and move it side to side a bit. If it has play between the crown race and the bearing you’ll need to try something else… Either reusing the old headset with new bearings or finding someone to get that race off for you.
If there’s no play, and the bearing only wants to turn rather than wobble then you are good to go. Just swap all the old parts except the crown race.
To be honest, unless you have the right tools, crown race fitting and removal can be a real pain.
CXR94Di2
I would dry assembly and check for smooth movement without any catching. If that works disassemble and grease mating surfaces.trohos
photo 3
photo 3
trohos
photo 2
photo 2
trohos
some photos
photo 1
trohos
The dimensions are the same, the problem is that the old crown race has a small log (about 1.5mm) that the new hasn’t. I will post some photos soon.Jack Osbourne snr wrote:So it’s an integrated crown race?Like I said above, compare the numbers on the old bearings with the FSA ones.
If they’re the same (which is highly possible) just fit them. If they look completely different, you’ll need to hunt for replacements on the net and return the FSA headset.
Jack Osbourne snr
This is the point where we start asking for photos so we can help more…
