Road disc brake problems
  • #27431
    SteeveB
    I need some help with my disc brakes!
    I am having a lot of problems with contamination of pads/rotors. Not really sure why but i now have two noise and vibration devices rather than brakes. The brakes are RS805’s from last year.
    Last night i sanded all the crap off the rotors. Got them nice and shiny. Sanded the pads  (they are the standard shimano ones that come with the brakes). Got them quite shiny. Cleaned everything with isopropyl alcohol (again). All went bad  when i cycled to work.
    Fixing the rotors is easy; just need sandpaper and elbow grease. But the pads are more of a problem.
    I have seen on some forums that people heat their pads to clean them. Anyone got any tips on this – how to do it? what temp to use? Does it work?
    Dont want to buy more pads if i can help it. Last lot are only a few months old.
    Never had a single problem with my MTB discs but the road ones are turning out to be a pain.
    SAB
Viewing 15 replies - 16 through 30 (of 47 total)
  • #898627
    SteeveB
    risoto wrote:
    Hi SteeveB,
    Everybody is talking about cleaning the pads. Have you tried to align the calipers?
    1. Loose the mounting bolts so the brake can move around
    2. Pull brake lever all the way (rather hard)
    3. While you keep pulling, tighten the bolts again.
    4. Release brake lever.
    5. Rotor should be perfectly aligned now.
    This more or less removed noise from my disc brakes.
    I dont think there is a alignment calliper probem; there is no rubbing. I have aligned them in the past.
    #898625
    huntswheelers wrote:
    Daily issue here in the workshop for Road Bikes on Discs….. not going to say Told you So….lol.
     It was in my workshop too; I too will try to resist the “I told you so”. The braking may be good, but the daily living with them is much more onerous. A road bike to me should be a thing of quiet beauty, which is not easily compatible with discs, either aesthetically or aurally.
    #898623
    huntswheelers
    Daily issue here in the workshop for Road Bikes on Discs….. not going to say Told you So….lol. We are fairly flat in these parts so disc brakes never get used hard and the way they were designed to so the contaminents from the bike, other roads users and weather never get “burned” off. For me it’s new pads all the time and keerrrchiiing in the till….    I guess it depends where you live, hilly areas will be best for disc brakes as they will be used the way they should be but for commuting and in traffic… then you will get contaminated…  Clean the pad material as much as you like with any of the suggested methods… but in the end you will be fitting new pads
    #898621
    IanEdward
    Guys, I’m actually amazed
    Guys, I’m actually amazed people are concerned about sanding the discs. This is a well established step in trying to solve contamination/squeeling issues.
    Remember when they are supplied new in the box, they are not a ‘polished machined surface’ but a matt, buffed looking surface, which almost looks like someone has taken a fine sandpaper over it, funnily enough.
    Obviously you shouldn’t be taking a belt sander to them, and obviously you shouldn’t be sanding away for hours and actively thinning the disc down, but I can tell you that for various reasons, I’ve had cause to sand discs numerous times, all you’re doing is taking them back to the state they were in when brand new, so yes, you have to bed them back in again, but no, you’re not leaving them more prone to contamination, no you’re not weakening them, no you’re not doing any permanent damage, etc. etc.
    That said, you should be using wet+dry, not mega coarse sand paper, and you should probably be putting that file down…
    Edit: re: prone to contimination, I guess if you sand the rotors but continue to use contaminated pads, then yes, you would be depositing contaminated material on the rotor. This step presumes using new pads…
    #898619
    dantheman1979
    As mentioned above check that
    As mentioned above check that your pistons aren’t sticking. Unfortunately if they are sticking and can’t be freed then its time for replacement calipers, because as far as I’m aware Shimano don’t sell spare pistons.
    #898617
    madcarew
    I don’t know if this will
    I don’t know if this will help on disc brake rotors, but as a chippy, when our ciricular saw blades get ‘contaminated’ with resin etc from knotty wood, leaving them soaking overnight in oven cleaner works a treat, as nothing else (turps / meths / petrol) shifts that stuff. Might be worth a try. I’d be really wary (as mentioned before) of sanding the discs. They’re a  polished machined surface, and unless you’re polishing with something like 4000+ grit wet and dry, then you’re likely to leave a surface which is far more likely to become ‘conatiminated’ due to the small scratches retaining contaminant materials.
    #898615
    risoto
    Hi SteeveB,
    Hi SteeveB,
    #898613
    http://www.discobrakes.com/?s
    http://www.discobrakes.com/?s=0&t=0&
    some great prices here and the quality is very good
    #898611
    SteeveB
    thanks again for all the good
    thanks again for all the good input. Will throw the pads out. That is ~£40’s worth. ouch. will try some of the cheaper ones suggested. if they get trashed it isnt so bad then.
    i sanded the rotors as no way was the crap coming off with anything else. I tried isopropyl alchohol,  muc off brake cleaner, jif, light sandpaper and then something coarser. It took some elbow grease to get rid of it. I saw sanding suggested on some mtb sites. seems to work okay but i hope i havent messed up the rotors.
    cqexbesd – i will try your advice on checking for a leak on the front brake. it must be a really small amount coming out. Nothing drips on to the floor under the bike for sure.
    The brakes seem much fussier than my MTB ones. I have cycled up to the axels in mud and never had a problem.
    Rode in on my old bike today. Was too scary to have no brakes.
    #898609
    graybags
    PaulBox wrote:
    I would recommend Uberbike components for pads, not worth messing about, just change them out.
    https://www.uberbikecomponents.com/category/324/Disc-Brake-Pads
    I was going to say exactly the same and in fact their website looks very similar to Disco mentioned earlier, could they be connected ?
    #898607
    PaulBox
    #898605
    LastBoyScout
    In all the years I’ve been
    In all the years I’ve been using disk brakes (mountain bike and hybrid), I’ve never once taken sandpaper to the rotors or scrubbed a set of pads to the extent described above – I use Muc-Off and then car shampoo to wash the bikes and give the brakes a good wash with that at the same time.
    I’ve used meths and brake cleaner a couple of times when I’ve serviced the calipers and cleaned the rotors.
    When I’ve had squealing brakes, it’s usually been down to a sticky piston meaning the pad on one side isn’t releasing properly (rode my sister’s bike from her house to my house with a howling front wheel because of this – it was a lot quieter when I rode it back!).
    If you’ve got vibration, then it’s also worth checking the hub bearings are ok – this is currently the problem on my mountain bike and will (kids permitting) be sorted this weekend.
    #898601
    cqexbesd
    IanEdward wrote:
    I’m a little out of touch with Shimano brakes, but I think leaking callipers causing contamination was a fairly well recognised problem.
    I had this. As did several other owners of Specialized Source Comp Discs I happen to know (Shimano BR-M506 brakes). Only solution we found was to replace the brakes.
    Once I guessed what was happening (and that took me a while) I could test it by putting the bike up on a workstand, cleaning thoroughly with alcohol and then putting a small piece of tissue between the back of the pads and the cyclinders.
    If I put it in and left it it would come out clean. If I braked hard a few times however it would come out with a circular stain of what looked like oil, but was presumably brake fluid.
    That tallied with what I noticed with riding the bike. I would clean everything and the brakes were quiet. Then they would slowly get louder as I rode but particularly if I had to do any hard braking. As time went on it would get noisy quicker so I guess the leak was getting worse. Eventually the noise would make babies cry, people to lean out of their windows to see what happened and for every man and his dog to tell me I either needed to clean my brakes, or oil them.
    #898599
    Jack Osbourne snr
    IanEdward wrote:
    IanEdward wrote:
    The advice from kev-s is good.
    Oi! I said all that first
    Ooops. Sorry!
    The advice from IanEdward is good too!
    #898597
    StraelGuy
    I have the same issue with
    I have the same issue with mine. Part of the problem is material related. Car brake discs are made of grey iron which has an extremely high self-damping ability which is why they rarely make any noise. Bike rotors are made of stainless steel which has a much lower self-damping ability and so are very prone to screaching in the wet. Unfortunately, at bike rotor thicknesses, grey iron is too fragile to make rotors out of indecision.
