11-28 to 11-32 advise please.
  • This topic has 6 replies, 6 voices, and was last updated 9 years, 3 months ago by Charlie-CarbsAndCycling.
  • #27419
    Dazad
    Hi, I have a canyon endurace with ultegra 11-28 and want to switch to 11-32. Can it be done and what else beyond cassette will I need. My mechanical knowledge is about as good as my hill climbing. Thanks in advance folks.
  • #898393
    You can run a 32 on all short
    You can run a 32 on all short cage rear derailleurs both 10 speed and 11 speed. It works perfectly, so you only need to change chain length if you want to run big big (cross chained). Wind the B screw in a bit and it will shift great. Look on youtube for tutuorials.
    #898391
    joeegg
    My Endurace is running a 32
    My Endurace is running a 32 as standard.
    #898389
    CXR94Di2
    Having looked at canyon, it
    Having looked at canyon, it says the current model has a GS rear derailleur. If that’s the case with your bike, just stick on a 11-32 cass. Slight adjustment of the B screw, job done 🙂
    #898387
    Daveyraveygravey
    If you have done a lot of
    If you have done a lot of miles you should probably replace the chain too
    #898385
    CXR94Di2
    Since you already have a 28t
    Since you already have a 28t Cass, you might get away with just the Cass. Adjustment of the ‘B’ screw to bring the derailleur back to clear the 32t sprocket. If it doesn’t clear then a ‘gs’ rear derailleur will be required.
    Shimano are overly cautious on the specification as to what will fit and what won’t. If you’re definitely going to get a 11-32, get this first and try if it works, then get the derailleur if doesn’t work.
    #898383
    charliepalooza
    You’ll need a Medium (GS)
    You’ll need a Medium (GS) Rear Derailleur. Other than that you should be good to go.
    Best thing I did getting 11–32 – saved my knees.
