cassette interchangability (if that’s a word !)
  • This topic has 2 replies, 2 voices, and was last updated 9 years ago by graybags.
  • #27376
    graybags
    I’m running SRAM Force CX1 on my cross bike but want to change the gearing to a closer range with fewer, large steps. At present I have a 42 up front and 11-36 at the back. SRAM 11 speed cassettes are a little more expensive than Shimano, so any idea if I can swop out and use an 11 speed 105 which is about £10 cheaper and also more widely available. I’ll be swopping out the front chain ring also, have gone with narrow wide from Superstar
  • #897627
    graybags
    Excellent, it does have that
    Excellent, it does have that prefix and I also now realise that I have a spare Ultegra cassette in the garage so I’ll give that a try.
    #897625
    If your current  SRAM
    If your current  SRAM cassette name starts with PG  (eg PG1170) then you can use the Shimano cassette. If it starts with XG you have the SRAM XD freewheel and they only accept SRAM cassettes (10 tooth compatibility apparently).
