- This topic has 12 replies, 11 voices, and was last updated 9 years, 4 months ago by .
I’ve been chasing down an annoying creak that is only present at the top of the power stroke (around 12 o’clock to 2 o’clock) and only under heavy power. Present on both sides.
I’ve ruled out (through part swaps or replacement) the following:
Pedals
BB
Saddle
Seatpost
Cleats (SPDs)
Shoes
Wheelset
Also present whether I’m in or out of the saddle and in all hand positions on the bars.
If I hold the rear brake on and push down on the pedal I can see visible flex (twisting) in the chainstays and this corresponds with the creak – once again it is present on both sides. I’m a heavy rider (120kg-ish), should I expect the frame to deflect that much?
Bike is a Merida Cyclocross 500. Thru-axle front, QR rear, mudguard fitted to chainstay bridge (I’ve lubed and tightened the fixing points for those)
