- This topic has 48 replies, 28 voices, and was last updated 9 years, 4 months ago by
joeegg.
June 23, 2017 at 10:20 am #27264
richcrocker79
I know this question has been done to death historically, but all of my recent googling brings up links and horror stories from four or five years ago.
My question is reasonably simple, I have a set of Fulcrum quattro carbons which i love. I am heading to France in a couple of weeks, staying near Mont Ventoux and riding up and down it a few times. Will I die on the descent if I use the Fulcrum rims? they have the 3Diamant braking surface, which is supposedly fine, but the best I got from Fulcrum was ‘we’ve never had any complaints about the braking surface’
Has anybody had any real world experience of a current technology set of carbon clinchers on long steep descents? I know they will get hot, I’m aware of not dragging brakes etc. but will they fail?
Thanks
Rich
freebsd_frank
The problem with carbon fibre
The problem with carbon fibre composite rims as compared to Al alloy rims is
that CFC does not have a specific heat capacity anywhere near that of Al alloy.What this means is that if you apply a certain amount of energy by way of heat
to a certain mass of CFC, it’s temperature will rise considerably more than
the same amount of energy applied to the same mass of Al alloy.That scenario is what happens when you’re going down an alpine pass. You’re
scrubbing of your speed big style and the energy you have is proportional to
your mass and velocity. You “lose” that energy when you apply your brakes but
it is largely gained by your rims resulting in a rise in temperature of the
material that they’re fabricated from.Al alloy: No probs. Large specific heat capacity. No failure of the rim or
glue attaching tub to said rim.CFC: Big probs. Low specific heat capacity so the rim gets hot enough for the
matrix material in the composite to melt – it’s just some shitty old polymer,
after all. Result? The walls of the rim fall apart, your tyre comes off and
you faceplant…if you’re lucky. If you’re unlucky, you’ll go over the edge
and an ambulance will come along and scoop up the bits of you they can find at
the bottom of the valley.I hear people saying: “But the pro’s ride CFC rims”.
Sure they do. But they’re paid a pile of money to do so; you’re not.
madcarew
Incidentally, my basic
Incidentally, my basic engineering tells me that Energy is proportional to speed squared, so if braking late and hard as suggested by many (to allow the rims time to cool down) I think is probably not good advice, as ultimately the rims have to get rid of more heat (as speed will have built up more in the interim). A safer approach would be to not let your speed get so high in the first place, but still corner as quickly as you can (to reduce the amount of speed loss required). I’m quite happy to be put right by someone with good engineering knowledge. I imagine it is possible (but I think unlikely) that the rate of heat transfer through the carbon may affect the answer.
madcarew
My recent experience (last
My recent experience (last weeked, and multiple times over the last 3 yeaars on a set of FFwd carbon tubs) is that they hold up just fine to long (7-12km) descents with frequent braking from 80+kph to +/-40 kph for bends. I’m 80 kg and descend very quickly. I haven’t ever had noticable brake fade on these rims (Swiss black pads BTW). My descents aren’t alpine descents, but the largest is a Cat 1 climb, 500m vert descent in 7 km with multiple corners and top speed of 80 – 85 kph. I’ve braked hard from 100 kph to stop on them with no issues too.
It is unlikely you will die due to the brakes’ performance. Your performance I can’t comment on 🙂
Nixster
That said, a carbon tubless
That said, a carbon tubless set up could get as hot as it likes, it wouldn’t blow any tubes.
[/quote]Assuming you meant ‘tubeless’ this is not true I’m afraid. At a certain point the rim will overheat and itself fail structurally. A tubeless setup has the same lateral forces on the rim wall as a tubed setup and it is this lateral force on weakened rims that causes some of the wheel failures.
Tubs have the edge here, if they get hot there is less stress on the rim as there isn’t any force required to hold the tyre on, the glue or tape does that. Or does that until it melts, which is a different but equally scary failure mechanism…
richcrocker79
MoutonDeMontagne wrote:Rich:I’ve got a set of Campag Bora clinchers, which have the same carbon 3Diamant braking surface as the Fucrums that you are running. I used them in the Alps last year (in 30deg plus heat), in addition to UK based hilly rides and haven’t had any issues at all. For ref, I use the supplied campag pads, and weigh about 78kg.
As you mentioned in the OP, I braked harder, but for less time, or if needing to control speed, say in a group, tended to alternate front/back/front so the heat didn’t build. Use your noggin’ and you’ll be fine, as will your wheels. The amount of people with popped tubes/rims (saw more Alu than carbon) on the Etape last year seemed directly proportional to the number descending like bambi with the brakes full on. Odd as riding downhill is not really different to driving downhill, don’t drag the brakes!
Thats great information, thanks Mouton – I’ve got about a kilo on you, so a perfect comparision.
I’m concious of the ride within your experience issue raised by others, but in reality being a UK resident down south, there is very little in the way of 13 miles descents to practice on, so we all have to start somewhere. I’m also mechanically sympathetic, and aware that all kit and people have limitations, hence asking questions before i go!
Of course I could just get a new bike with discs, but I’m trying to avoid opening that can of worms on a forum!
Cheers
Rich
Jackson
Pros don’t suffer wheel
Pros don’t suffer wheel failures on descents because they ride tubs, don’t brake much and weigh about 68kg on average, so the point above about pros going 120km/h and being fine is meaningless. It’ll be the 85kg MAMIL panicking at 50km/h on his fancy clinchers who’ll blow one apart and get a mouthful of tarmac.
If you’re light enough to need super light carbon climbing wheels you’ll be fine. If not, just take aluminum box section wheels for peace of mind, as it’s obviously playing on your mind enough to make a post about it.Jimmy Ray Will
I do agree however, that
I do agree however, that people should probably avoid riding terrain they are not comfortable in, on equipment that has been optimised for racing conditions.
So… if you can’t descent without iding teh brakes, use brakes that won’t suffer from over heating.
MoutonDeMontagne
Rich:
Rich:
Jimmy Ray Will
BehindTheBikesheds wrote:Jimmy Ray Will wrote:it all depends on how you descend and how heavy you are, and how hot it is.I’d also imagine that tyre and rim width will play a factor.
If you are relatively heavy, and like to drag a brake, then yes, there is a real risk of you blowing tubes on long, hot descents. if however you don’t letting the bike go, before hitting the anchors for turns etc. then you shall probably be fine and dandy.
The problem with carbon rims is that they don’t shed braking heat quickly. Different resins, and using more effective braking surfaces can reduce heat build up a bit, but fundamentally a carbon rim is going to get hot and stay hot when being braked.
There is no fool proof solution to this sadly… which to me is another reason why the industries are pushing discs so hard.
I agree with all that you’ve said bar the disc aspect. How often do the pros, well actually anyone crash on high speed wet descents due to actual inadequate braking power on carbon rims?
Aren’t incidents a combination of not understanding the limitations of your kit in X conditions and failing to adapt to that, AKA pushing the boundaries and going beyond and then most of all find that the limiting factor is in fact the human in their judgement and the tyres not the brakes themselves?
Yes, in the wet, discs have a clear advantage (over rim brakes) in ultimate braking power and how much later you can brake to stop at the same point, also for some who don’t bother to learn how to control the amount of braking will be helped out by discs in that respect too (modulation).
However similar with motorvehicles, you’ll end up with people pushing the new ‘envelope’ same as before, gain more confidence so braking much later and finding that they no longer have sufficient thinking time in certain instances and braking later means the tyres are going to lose traction more often due to much harder, later braking from higher speeds in the wet thus we will still have the same amount of crashes if not more due to these factors.
The ‘solution’ is not go with a system that is cumbersome/ugly and adds weight/changes where the stress points on the frame and forks are, and loses a significant amount aerodynamically (all negatives IMHO) but to learn when you need to brake in x conditions at x speed, learn how to navigate descents and bends better/safer without having to be on the brakes all the time, learn how to modulate your braking and that if you can’t descend to a reasonable standard and be safe with respect to yourself and other road users then maybe think long and hard about where you cycle and if the conditions/terrain is beyond your and your bikes capability just stay away and choose something less risky.
Just because one has a bike similar or even better than a pro doesn’t mean you have any business being in certain environs trying to copy them, particularly in not so great conditions. Doing so has catastrophic outcomes all too often and discs will not resolve this at all.
If discs were so great why do we still have millions of crashes in motorvehicles every year in the UK alone with 185,000 killed or injured despite all the protective systems in modern vehicles? it’s not the brakes themselves but the higher speeds, later braking, loss of traction of tyres and smaller window of thinking time for the human.
The ONLY reason manufacturers have come up with discs is to make money, they can try to sell it as a safety feature all they want but it’s totally bogus.
If the OP is concerned and doesn’t have the required experience/skill (it sounds to me they don’t) then I suggest they simply stay away from the descent mentioned and go ride somewhere where they are within their experience/skillset until they are sure they can do so safely with the kit they have, this should apply to all. I know and have seen even in the pro ranks of too many people riding beyond their capabilities and coming a cropper, great athletes but not so good at understanding X, Y and Z.
Yar, you may have missed the point I was making about discs. One reason the industry is keen to push them is because there is no ultimate ‘fix’ for carbon clinchers. Carbon will always get hot, which in turn heats the tubes, which in extreme scenarios causes blow outs. These are common enough to be a recognised problem in ral world riding as; not everyone is under 75kg and not everyone has the ability and desire to let a bike go on a steep / long descent.
The only definitive fix for carbon clinchers is to remove the braking surface away from the rim… hence the disc requirement.
carbon rims are more expensive, and more desirable than alloy rims, so naturally something the industry wants to keep.
surly_by_name
Don’t drag the brakes. Brake
Don’t drag the brakes. Brake on the flat bits before the steeps (so don’t carry speed into the 12%+ sections on the way down to Malaceune). Brake late, hard and for a short period so as to let rims cool (a bit). Use carbon specific pads. Some of the posts above ramble on a lot about all manner of unrelated things. Use your head and be sensible. You’ll be fine.
700c
Agree with the above about
Agree with the above about riding within your skill level and equipment limitations. That’s the key point.
As for rims overheating, there are still valid concerns about carbon clinchers on long descents overheating and blowing the tubes, but just adjust your speed and style accordingly and you should be fine.
Huw Watkins
Mavic’s coments from one of
Mavic’s coments from one of their recent wheel launches:
“At the 2015 Etape du Tour, for example, Mavic assisted with 100 wheels, of which 52 were failures and 38 were carbon clinchers that had delaminated, product manager Maxime Brunand said.”
Tour magazine did a big carbon clincher test last year and a couple failed under heat duress but none of the failures were either Fulcrum or Campag. Campag Boras won the test overall so I think its safe to say that Fulcrums will be just as well put together.
Sniffer
wellsprop wrote:No real world experience, but…Look at the speeds the pros were hitting in the Tour de Suisse, 120kph+, their wheels didn’t fail.
Not to say they don’t fail – ever seen the video of the guy riding a Canyon down Mount Ventoux and he overheats the pads?
Comes down to how heavy you are and how much breaking you are doing. Personally, I wouldn’t be too worried about using a pro level set of carbon wheels on a descent, one would hope that they have been tested and designed against failure.
Not sure Pro experience helps the OP. Pros don’t ride clinchers, they ride tubs.
Jimmy Ray Will
