11 Speed Chainset Compatibility With 10 Speed Setup
  • #27182
    jonoace
    Hi just want to ask for some advice, can  a 11 speed chainset work with a 10 speed setup (mine been Sram force setup 2012)
    However I am currently using a Utegrea 11-28 cassette and 10 speed chain they both work fine with Sram setup.
    I am having to replace my FSA SLK CARBON LIGHT CHAINSET(53T-39T) , main reason it has  worn out the chain rings on the big ring and the BB is on its way out ,and getting these alone is very expensive!!
    So it was more cost effective to purchase a Shimano 5800 11 speed chainset and 2 Shimano Dura Ace Bottom Brackets for a good price from Ribble Cycles.
    I have Herd that the 10 speed setup will work fine with the 11 speed chainset. I am also going to replace the chain With XL KMC chain 10 speed.
    The 5800 Chainset is a 52T-36T that I have Purcased. Any help and advice ,or if someone has used a 11 speed chainset on 10 speed setup I would be grateful for any information including set up. Thanks
  • #894307
    spj7
    I run new Tiagra 10spd with a
    I run new Tiagra 10spd with a 105 11spd chainset as I wanted a double. No issues whatsoever and I set it up no different to any other chainset.
    #894305
    drpau
    I use 6800 Ultegra (11s)
    I use 6800 Ultegra (11s) front crank and 6800 FD with 6700 10 sp rear derailleur. No issues.
    #894303
    jonoace
    Thanks for the replys guys.
    Thanks for the replys guys.  Hoping to get all setup this week ,new chain,bottom bracket ,and chainset.  Shall be climbing over The Serra Candeeieros In Portugal.
    #894301
    TypeVertigo
    Most chainsets don’t really
    Most chainsets don’t really care how many cogs you run at the back. Don’t worry about chainset compatibility.
    I’m told Campagnolo seems to be exception, but that’s irrelevant to your case.
    #894299
    jonoace
    3rd picture of the bike shame
    3rd picture of the bike shame about the chainset good service over 5 yearsindecisionindecision.
    #894297
    jonoace
    2nd picture here
    2nd picture here
    #894295
    jonoace
    1 picture
    1 picture
    #894293
    jonoace
     Hi Steve thanks for your
     Hi Steve thanks for your kind response, sending some pictures of the chain stretch, 1st picture on the 0.75%  chain marker tool just about fits inside the chain.
    2nd pic its  sits on top on of the chain the 1.00% mark.
    #894291
    StraelGuy
    Should work. My winter bike
    Should work. My winter bike is all 11 speed 5800 105 but with the 10 speed 5700 crankset. Bugger all difference as far as I can tell.
    #894289
    SteveAustin
    Should all work fine.
    Might want to check chain stretch. old chains can jump a fair bit on new chain rings
