- This topic has 8 replies, 7 voices, and was last updated 9 years, 2 months ago by .
I’ve just ordered a new winter bike (Canyon Inflite AL9s), which happens to come with a semi-compact Ultegra chainset (52/36 mechanical). After a bike crash in January when I fractured both wrists after coming a croper on some ice, I wanted something I could use offroad if it’s wet and cold with just a change of tyres.
On my best bike I’ve Ultegra Di2, after much procrastinating I went with a compact chainset on that bike (50/36). Both bikes have full Ultegra groupsets, the only difference being one is mechanical and the other electric, both have 11-32 cassettes fitted.
I’m contemplating swapping the rings over between the bikes, it doesn’t make much sense for my winter bike to have higher gearing than my best bike.
I’ve had a quick look online, I hadn’t realised that I couldn’t just swap the rings across without having to dismantle anything. I seem to have all the required tools already as I had to pick a BB removal tool the other day to swap my Centrelock disk rotors around.
I’m now thinking I may as well just swap the cranksets between bikes – I assume there is no difference between a mechanical and Di2 crankset? The chain lengths may be slightly different I guess, but both are using a Shimano HG11 Ultegra chain anyway – and I’d fit a quicklink to the new bike as a matter of course – so I may as well swap the chains across at the same time.
Would I need to adjust the FD heights going from a 50 outer to a 52 and vice-versa? I’m very wary about anything BB related as its one of the few areas on a bike I’ve not ever performed any maintenance on.
Just how much hassle would this be?
