- This topic has 5 replies, 5 voices, and was last updated 9 years, 7 months ago by .
I have a bike with missing parts and I need to replace the crank. It’s a 2×6 drivetrain. The bottom bracket appears to be around 68mm. with outboard bearings it appears to be 89mm, and the spindle is about 18mm, though looking around I think I totally messed up as the smallest seems to be 24mm? . I’m really not dead sure as Idon’t have a caliper. It also appears to be 175mm crank arm length. It also appears to be ISIS?
I’m hoping someone will instantly know what I have and possibly suggest a cheap replacement! 🙂
All Im missing is the crank arm and whatever secures it on, but the crank markings are so worn I don’t know what it is. I think it best I just pick up another crank if I can find one, and i really want 170mm which is better for me; i plan to use this bike on the trainer.
Here are a couple photos. I’m hoping someone can tell me the standard I’m after to replace it? I guess I can replace the outboard bearings too if needed.
Photos:
https://goo.gl/photos/Z4W3STkv4H9yCH5aATks!
