- This topic has 15 replies, 8 voices, and was last updated 9 years, 6 months ago by
mattydubster.
March 12, 2017 at 4:23 pm #26880
I’ve got hold of a couple of Schwalbe S-One tyres (700×30) from EBay and I’m not sure if they’re tubeless or not. I’m currently running Schwalbe Pro-One tubeless and they say “TL-Easy” on them, but I’m concerned that the S-Ones only have “Performance Line Raceguard” written on them. Does anyone know if these are tubeless?
mattydubster
I have Shwalbe X ones for the
I have Shwalbe X ones for the winter then put S ones (30mm) for summer. Both are easy tubeless and I honestly have to say I wouldn’t ever go back to inner tubes. EVER.
I go on trails a lot and we have loads of thorns here in East Anglia, have pulled 3 out now and the sealant has taken care of them all.
So get them sold and go tubeless
riotgibbon wrote:something I learnt today is that the sealant in tubeless tyres can cause problems with the spokes. I’ve buckled my rear wheel, and the mechanic at my local shop is having trouble with the spokes – it seems the sealant gets under the rim and into the spoke nipples – hilarity ensues!Ideally the rim should be air-tight so that sealant doesn’t get onto the nipples, but I suppose you only discover that when it’s too late.
I might end up selling these Schwalbe non-tubeless S-One tyres. Any takers for 30 quid each?
Jimthebikeguy.com
Not if the wheel has been taped or prepped correctly.
riotgibbon
CXR94Di2 wrote:I would like to know how a normal road tyre would have a ‘catastrophic depressurisation’ ? The benefit of sealant it reduces rapid air loss.Tubeless tyres have stronger beads and sidewalls. The risk is the tyre coming off the rim.
hawkinspeter wrote:So, I’d better be putting tubes in these ones then.Yes
jterrier wrote:
jterrier wrote:The performance line tires from schwalbe are not tubeless. They are the mid range models.So, I’d better be putting tubes in these ones then.
CXR94Di2
KiwiMike
jterrier wrote:
jterrier wrote:The performance line tires from schwalbe are not tubeless. They are the mid range models.A year ago I raised the issue that bike brands were shipping OEM-only versions of Schwalbe tubeless models that were *not* tubeless, on bikes selling with tubeless-ready rims. This to my mind was reckless. I imagine many customers thought they were tubeless ( I did, and it took a LOT of research to confirm they weren’t). I bet many pulled out the tubes and added sealant. And risk a catastrophic depressurisation.
Jimthebikeguy.com
. . wrote:iso2000 wrote:Mine have “Tubeless Ready” and “V-Guard” printed on them.Same here. Like in this pic http://www.cykelportalen.dk/wp-content/uploads/2016/04/Schwalbe-S-One-02.jpg Mine were from Wiggle about 6 months ago
Would you mind posting a link to the EBay ad?
The tyres I bought were these ones: http://www.ebay.co.uk/itm/162387332102?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
I think those were the only 2 that they had but here’s a link to their shop (they delivered nice and quick): http://stores.ebay.co.uk/activesport-store
riotgibbon
hawkinspeter wrote:I thought the G-One was a bigger tyre – the S-Ones that I’ve got are 30mm. The tread looks the same as the G-One though.it’s the G-One *speed* that’s the S-one replacement, I’ve got a 30mm one. There are other G-Ones that are much bigger:
http://www.chainreactioncycles.com/schwalbe-g-one-all-round-road-tyre-microskin/rp-prod154970
but presumably not as speedy …
CXR94Di2 wrote:S One now renamed G One speed. In S One, they did two types a tubeless version and tubular. So it looks like it is tubeless.I have the G One 40mm and it comes with various models, some not classed as tubeless and inner tubes are required.
I think I’ll try fitting one of them again now that they’ve been hanging up without being folded. The problem I had previously could have been due to the bead being a bit kinked.
iso2000
Mine have “Tubeless Ready” and “V-Guard” printed on them. They were bought about 2 months ago but may have been from old stock.
CXR94Di2
S One now renamed G One. In
