- This topic has 12 replies, 7 voices, and was last updated 9 years, 4 months ago by .
Hi all,
Just went out to garage and front tyre was almost flat, rear tyre totally flat and had popped off the bead. Thankfully popped back on with track pump.
Schwalbe Pro Ones 25mm on 18mm internal DT Swiss tubeless ready rims.
DT Swiss tubeless tape and valves. Put in 50ml of Stans sealant. Left them with 110psi in to help tyre stay on rim.Tyres went on last weekend, front one track pump and rear one with compressor. Did an hour ride the next day, the front had lost 20 psi that first night but rear was still perfect.
I think I am losing pressure around the valves with tiny leak, have tried them pinch tight and also really tight. The sealant doesn’t seep out anywhere but guess is hard to get sealant around the valve being on inside of rim.
Anything I can do to get them seal better or any other valve options?
