- This topic has 14 replies, 11 voices, and was last updated 9 years, 4 months ago by .
Hi all
I have a Garmin Edge 810 which is still within its 12 month warranty period. I’ve used it only a few times since buying it because of the winter nights but now I want to use it for longer more exploring rides. So I want to use the navigation function. I’ve installed the open maps and using a ride I have done before created a course.
Although I can use the 810 for recording a ride, every time I have used it to navigate a course it switches off. It did this several times, I thought that there could be an issue with the courses, but I did a sportive and used the gpx file and it crashed and switched itself off again.
I’ve emailed Garmin Tech Support and they said update the software and do a master reset, which I did and tried using it again. 3 minutes into navigating a ride it stopped working and switched itself off.
I can send it back I know, but it does seem that it could be quite good, if it worked. My question is should I persevere and try and get it fixed or am I best sending it back and trying something else?
If so what else, in the £200 or below price bracket?
