- This topic has 4 replies, 3 voices, and was last updated 9 years, 9 months ago by .
Hi
I’ve changed my Rear Derailluer for an x-9 from an ultegra on my TT bike !!
It’s a 9spd Shimano cassette with Shimano bar end shifters which aren’t indexed, they are just pulling the cable through and as it’s a TT bike I manage the cable pull manually instead of relying on indexing.
The X-9 has a longer cage which enables me to run 16T ceramic jockey wheels.
Problem is I can’t get the derailluer to span from the lowest to the highest, it’s an 11-25 9spd cassette so well within the derailleurs range, but if I set the cable up to use the 11T gear with shifter at it’s slackest but cable tight, and then move the shifter to pull the cable all the way through it doesn’t hook onto the 25T cog, it will get to the penultimate but no further. Like wise, if I setup the cable so that it is on the 25T cog I can’t get it to shift all the way down to the 11T cog.
I have fully opened the restraining bolts so that’s not stopping it. previously I had an ultegra 6800 derailleur which worked fine and would shift from lowest to highest on the same cassette.
So I can’t work out why the same cassette (no change in low to high cog range) and the same shifter (same range of cable being pulled through) can’t move the derailluer enough. I understand the Indexing isn’t going to work, but I’m not using indexing i’m purely using cable tension to change gear.
Any ideas would be fun to hear.
Gc
