- This topic has 7 replies, 5 voices, and was last updated 9 years, 9 months ago by .
The Bike Bridge approved by Mayor Sadiq Khan (in October 2016) is a great idea. But it’s in the wrong place, partly because it was planned using the Sustrans Cycle Map. Using data from the Strava App it is clear that it does not connect with the routes cyclists use.
The LAA is calling for it to be moved to Deptford, where it will have a much better connection with Cycle Superhighway 4, on Evelyn Street, which the Mayor has approved. In this location it would also relieve congestion in the Greenwich Foot Tunnel, save Durand’s Wharf Park from becoming a grassy backdrop for engineering infrastructure, and provide commuters from SE London with a faster route to Canary Wharf and the City.
East London needs new river crossings and a bike bridge would be very welcome. But the location needs to be chosen with regard to local cycle movements and the local landscape. So the Brunel Bike Bridge should be moved a 1500 m downstream, to Pepys Park. The west access ramp would flow into an existing footpath with an east-west alignment. The east access ramp would join the proposed north-south riverside cycle superhighway on the Isle of Dogs. Located here, the Bike Bridge would provide a short and direct connection to the CS4 Cycle Superhighway, which Mayor Sadiq Khan has approved. He has also approved the Brunel Bike Bridge and the two projects obviously need to work together and make their contribution to East Central London having cycle infrastructure which is as good as West Central London.
