Broken adjuster – What’s it called and can it be replaced?
  • #26635
    BikerB
    Hi,
    I’ve some how broken my cable adjuster. What is it called? And can a replacement be easily sourced?
    This is a photo of the cable adjuster i’ve broken.
    https://s28.postimg.org/8549n0qa5/2017_01_08_20_12_33.jpg
    Also does anyone have an idea on how to get the remainder out of the frame?
    Thanks
  • #884663
    BikerB
    dottigirl wrote:
    Not as far as I’ve experienced. Think you could be right about it being from a mech. They probably heard ‘cable adjuster’ but didn’t process the ‘downtube’ bit. I had that happen a couple of times when I was looking for them.
    They are rather fiddly to screw in though as you should be fighting the spring. I dropped one several times and had to locate reassemble the pieces (there’s three – the inner screw bit, the spring, and the outer shell).
    I managed to screw it in by a millimetre to two but no more than that. When i put them side by side, the new does look a tiny tiny bit larger than the old. I’m only talking by about a millimetre.
    #884661
    dottigirl
    Not as far as I’ve
    #884659
    BikerB
    Do the threads of barrel
    Do the threads of barrel adjusters vary in diameter?
    A LBS sold me one, it looks like the adjuster for a derailleur. I attempted to fit it when i replaced the cable but it wouldn’t screw in to the lug.
    #884657
    dottigirl
    It’s a ‘downtube cable
    It’s a ‘downtube cable adjuster’ if you’re asking in a shop or looking online.
    They can corrode quite badly and a lot of people forget to clean/protect them. I’ve found many shops don’t carry them, or you may end up with an unmatched pair. I’m guessing by the state of your bike that won’t be a problem though. 😀
    #884655
    pockstone
    Screw removers are available,
    Screw removers are available, try something like this:
    It might be a bit inaccesible,  but filing a slot into the broken threaded adjuster w ith a needle file might allow you to turn it with a flat bladed screwdriver. Alternatively…and entirely at your own risk..  you could find a  tight fitting Torx bit that you can tap into the offending item and turn with some pliers. I’ve used this method with a rounded off allen (hex  key) screw and it worked a treat. Take care though!
    #884653
    Redvee
    Looks like there’s a threaded
    Looks like there’s a threaded part still stuck in the lug. Try screwing a thin wood screw in from the bottom and this might turn the threaded part and give you enough to grip it better.
    A replacement from PlanetX like this will be OK as they are a 4mm thread.
    http://www.planetx.co.uk/i/q/GXPX7900/dura-ace-7900-tt-style-frame-mount-gear-cable-barrel-adjusters-(pair)
    #884651
    BikerB
    longassballs wrote:
    Poke it out?
    local bike shop will sort you out.
    Is it not screwed in to the lug on the frame?
    #884649
    longassballs
    Poke it out?
    Poke it out?
