- This topic has 9 replies, 9 voices, and was last updated 9 years, 8 months ago by .
Interesting problem this week! So as many of you know this week was minus 7 degrees centigrade (19.4 Fahrenheit) in the night in many parts of the UK. The wife left for her commute at 6:30am on her GT Grade with the TRP HY/RD brakes. Ten minutes later comes back, the rear brake has seized on, the the brake lever has gone “floppy” like the cable is not “returning” so it’s not springing back.
I have the TRP Spyres, exactly the same thing happened to me half an hour later!! Rear brake seized on after the first pull. Lever goes floppy.
Upon having a look at them, I reckon it’s because the holes for the cable to come through mean that the cable outers are facing upwards, therefore allowing water to get down inside the cable outer. Of course when you go out into the cold and start cycling, this freezes, meaning the rear stops working. On the front brakes, the outers both face downwards, so it’s not an issue. Any idea how to solve this one? Otherwise it means the bikes can’t really be ridden if it’s really cold. Obviously I’m now going to have to cover up the rear calliper when I wash the bikes. But water might still get in from rain.
Looking to you guys for a solution to stop it freezing up. I’m thinking, disconnect it, try and pour the water out, maybe add some lock anti-freeze, and a “v-brake” rubber boot thing, maybe packed with marine grease, to cap it off. What do you reckon?
I want to sort it out cos I thought disc brakes were awesome up to this point!
https://www.instagram.com/p/BNfLDKTjggX/?taken-by=stefmarazzi
