tyres
  • #26486
    Alfa a
    Hi All
    I’ve had my GT grade a few months now and feel the need for new tyres as the grip isn’t so good from the supplied ones and I’m going off road a fair bit.  I have brought a Continental Cyclocross Speed Folding CX Tyre (700 x 35c) thinking they came in pairs ! Would anyone recommend mixing tyres, so having the cyclocross tyre on the front and supplied road tyre on the front or vice versa?
  • #881791
    Alfa a
    Thanks for the replies.  I’ll
    Thanks for the replies.  I’ll put the cyclocross tyre on the front and give it a go but I’ve ordered another tyre just in case!  I’m far from a racer at the moment but really enjoying my cycling now and hoping to get to the stage where I can enter a few races.  Perhaps now is the time to experiment!
    Thanks for all the input
    #881789
    surly_by_name
    Cross is a bit traditional
    Cross is a bit traditional inasmuch as its unusual to “mix” tread, i.e., if you’ve got a Rhino on the front you’ll find the rest of the grid pointing and asking questions if you have a Typhoon on the rear.
    On the other hand, this has been going in mountain bikes for a long time – very common to put something with more grip on the front matched with something faster in the rear. Theory being that unweighted front needs more grip (esp as front wheel wash out harder to rescue/more catastrophic than rear wheel wash out).
    I think its a good idea on the right course.
    #881787
    Ad Hynkel
    I would have thought off road
    I would have thought off road you’d want the good grip at the front for the very reason above. I think from the little I have gleaned about cyclo cross tyre mixing this is the way to go. There’s a discussion here:
    http://cowbell.cxmagazine.com/forum/topics/mix-and-match-tire-treads
    but it doesn’t sound cut and dried from a reacer’s perspective.
    #881785
    kil0ran
    Did this recently whilst
    Did this recently whilst waiting for a wheel build. Rear was knobbly, front was slick (Gatorskin). 32mm tyres. Coped OK with gravel tracks but I was cautious about pushing the front. If I was to run it permanently I’d want more grip at the front as its much easier to control the rear stepping out of line than the front tyre washing away (unless you’re Marc Marquez)
    #881783
    peted76
    That sound bonkers, however
    That sound bonkers, however that tyre you’ve brought isn’t that knobbly, so you’ll probably live, just about…
    However I’m not sure having the knobbles on the front is better than on the back.. might want to think about the type of riding you do before making that decision, more weight on the back most of the time.
    Frankly I’d say spend the £20 and get another one.
