- This topic has 14 replies, 10 voices, and was last updated 9 years, 9 months ago by .
Hi all
I wonder if someone might help with a shifting issue.
I have tiagra 4600 on my caad x and I recently changed the cassette, chain, inner and outer cables. Since then the shifting is 90% okay but sometimes it doesn’t want to shift up the block (to a lower gear) on 1 particular gear, halfway up the block. All the other gears are fine and it changes into all the smaller cogs.Since I have a medium cage and a long cage I tried the other Rd and same problem.
So I have now changed the mech hanger and it shifts even better, except for that 1 gear which is always much slower to engage.
It’s really frustrating when I’m riding and I slow my cadence slightly for the gear change and it doesn’t go in, so then I’ll need to push the sti until just before it clicks to get the change and by then I’ve lost all my momentum.
What have I done wrong?
Thanks, Andrew
