- This topic has 22 replies, 17 voices, and was last updated 9 years, 7 months ago by
Anonymous.
October 31, 2016 at 1:53 pm #26450
the_mth
I’m looking to get an indoor trainer for over the winter. I spent months picking a bike and fancy a TV in the New Year sales so that’s more months of research so I’m hoping just to buy a trainer without thnking too much!
Most places I’ve seen pick the Tacx Vortex Smart as the mid range one to go for. I had a few questions about the software to go with it.
1.) I dont have a laptop or dekstop and operate entirely off an Android phone so I think that for the moment rules out Zwift which requires a PC/Mac?
2.) I downloaded Trainerroad just to have a look at the app. Again, I think this requires a monthly subscription to work? Does it have real life rides ? Can i program my own or just use what ones they create?
3.) The tacx app doesnt seem to easily export to Strava, is that still correct? Does Trainerroad?
4.) Is there any software where I could download rides, for free or paid, and then just use them as and when without the need for an ongoing subscription? That is, I could subscribe to something for a couple of months over the winter then have a few rides downloaded I could use when I wanted over the summer if I couldn’t get out.
Cheers!
chaloum wrote:Zwift is coming out with the simulation on iOS and most probably Andriod. I don’t find Zwift compelling as a training app and I got bored with it rather quickly. How may times do you want to ride around London or the Island.Trainer Road is a great training app but as you have pointed out it’s a subscription model about $100 per year but it’s structured training. The thing about Trainer Road is that you can use it with a standard trainer and Trainer Road will give you virtualise power. so you don’t need a smart or expensive trainer.
Wahoo have a reasonable app which works with their trainers the expensive Kickr and the cheaper Snap and the data .
There are many ways to get data onto Strava. there are many posts about getting data from one app to another on the internet, It may require several apps like going through Myfitnesspal or another fitness app.
So it really comes down to what you’re wanting to get out of you training.
Zwift will also do virtual power (“Zpower”) which I’ve found perfectly adequate, and it also has a workout module. Each to their own of course but if you got bored on Watopia I’d suggest you’re either not riding hard enough, not participating in the group rides/races or just have a very low boredom threshold.
chaloum
MoutonDeMontagne
I really ‘like’ the
I really ‘like’ the sufferfest videos, and find they make the turbo far less boring than watching boxsets, mostly i think because they’re interactive. If you don’t want to go hard, use the Col Collective editions. Can easily spend an hour/ hour and a half spinning away to those but only about 20 min watching tv. The other thing I found is getting a direct drive trainer (elite turbo muin) saves a lot of faff and are so much quieter it somehow makes it more enjoyable, maybe its not having to wear headphones or just losing the droning noise my mag trainer used to make. You can set most things up to do virtual power now using the sufferfest/strava so no need to spend a fortune unless you’re desperate to use zwift etc.
The _Kaner
“Am I right in thinking that
“Am I right in thinking that if I buy the trainer I will also then need to buy an ANT+ dongle for my phone so it can communicate with the trainer?”
Android? How Old?
Check here if your phone will natively support Ant+ – then you could download ant+ app from play store without need for a dongle
https://www.thisisant.com/consumer/ant-101/ant-in-phones
(My Samsung S6 doesn’t require any dongle – use it with Strava mobile app to connect to Cad/Spd and HR).
I’ve just bought an Ant+ dongle from ebay for about €13 all in (same one can be had off amazon too, but postage to Ireland is about the same cost as the dongle).
It’s a USB type, but you can get micro usb for phone too… I am going to use it so I can run Zwift on the pc (2 months free subs on Strava), mirror to big screen TV and use the (dumb) turbo along with the garmin speed/cadence sensors. Zwift uses a calculated power curve for non smart turbos…I guess for minimum outlay – as I have the turbo already – it’s worth a punt…
Get a cheapo PC and Zwift.
Get a cheapo PC and Zwift. Being able to ride with and against other people, in varying scenery, is priceless. You don’t even need a ‘smart’ trainer, although a Vortex is a great place to start.
Nick Kanwetz
the_mth wrote:Am I right in thinking that if I buy the trainer I will also then need to buy an ANT+ dongle for my phone so it can communicate with the trainer?Tacx seem to do the only micro USB one but could a normal USB ANT+ dongle be used connected to the phone by a OTG USB adapter cable?
I do plan on buying a laptop next year to replace my aging desktop but where I’m living at the moment for work has very slow broadband, less than 1Mb. I get decent 4g coverage though so just use my phone for nearly everything. The laptop option seems the easiest way and gives you the widest choice of apps.
Would anyone know if I use Trainerroad on my android phone can it be minimised and let me watch Netflix/Amazon while it works away in the background?
If it won’t do this I see from the Trainerroad FAQ page that it doesnt need an internet connection to work once everything is downloaded so I could use a tablet I have lying about to record workouts and stream from the phone.
Currently, in order to connect the Tacx Vortex Smart to TrainerRoad, you’ll need ANT+ connectivity. The good news is many Android phones have ANT+ built-in so you won’t need any additional adapters. You can learn more about how to connect TrainerRoad to your Android phone here. If your phone doesn’t have built-in ANT+, you can use the ANT+ USB dongle and OTG adapter cable though.
Also, you’re correct that TR requires a subscription. We offer a $12/mo and $99/yr option, and also have a 30-day money-back guarantee. If you don’t absolutely love us in your first 30-days, we’ll get you a 100% refund no questions asked. đŸ™‚
The Tacx Vortex Smart is an electronic trainer that will, in conjunction with TR, electronically control the resistance of the trainer to make sure you’re hitting power targets within your workout. So it’s totally cool if you switch apps over to Netflix/Amazon. TR will still be controlling your trainer while you’re watching your entertainment. Your tablet solution could also work as well — it’s up to you.
Feel free to let us know if you run into any questions or concerns at support@trainerroad.com. We’ll be happy to help!
Cheers!
Community Manager at TrainerRoad — Cycling’s Most Effective Training System
carytb
+1 for Trainerroad. In my
+1 for Trainerroad. In my view excellent value for money. I really enjoy the podcasts
Also get a decent trainer. I started off with a cheap Minoura Electro magnetic one. It was awful. I then got a Kurt Kinetic Rock & Roll. Its the diference between night and day.Far closer to the feel of road riding. It’s not a patch on riding outside in decent weather but it certainly beats riding in the cold and wet and on icy roads.
A good fan makes a massive difference. I got this one from Argos and it does the job perfectly
http://www.argos.co.uk/product/4250090
King_Louis
I link my Vortex with my
I link my Vortex with my iPhone through Bluetooth. I second what a few people on here have said. Make sure you really want a trainer. I bought mine and got bored quickly, until I found zwift. I feel like I can engage with it as there is a visual stimulus, although half the time I have zwift on my laptop and Netflix on the tv.
Once you get it cracked it can be really useful, especially the power training workouts.
the_mth
CXR94Di2
I love indoor cycling. I use
I love indoor cycling. I use bkool mainly for league racing a couple of times a week, I have tried Swift(similar to Bkool) I have also just started training plan on trainer road. Get a fan, then a bigger fan. I use a 3ft industrial fan and still sweat up. It can be really hard work if you want it or easy to do a couple of hours zone 2.
My health has been much better for not riding/training outdoors during winter, hardly a cough or cold.fustuarium
Â
1) Don’t know about Zwift
2) TrainerRoad is monthly. You can get a free month from existing subscribers (loads on here I imagine including myself). It doesn’t have ‘real life rides’ but does have rides that match some real life training videos if that makes sesne. You can build your own workouts in the workout builder. Very questionable whether its worth trying to do ‘real life rides’ on a turbo as it misses the point of the structued programming that is so effective. Have a listen to the free podcasts they do. They talked about mimicking real life rides in one of the recent episodes.
3) Not sure about Tacx app as I don’t use it (eventhough I have Tacx Bushido). Trainerroad exports to Strava automatically and it’s a doddle to set up and link the accounts.
4) I think there’s a few different ones. As others have said, read DC RAinmakers site as he does a review of turbo trainer software as well the units themselves. I’m on annual with Trainerroad as I can watch the World Tour races on Eurosport during the summer whilst getting a ride in; killing two birds with one stone.
Team EPO
Worth a read of the mighty DC
Worth a read of the mighty DC Rainmaker’s trainers
https://www.dcrainmaker.com/2016/11/trainer-apps-guide.html
His website has 3 MILLION visitors a month!
pablo
I have tacx vortex smart does
I have tacx vortex smart does the jon but still nothing like riding on the road. I’ve used their app but only for ERG control and don’t bother now.
I used Zwift last year which was great and does have a way of program workouts or pre de-defined ones it certainly did break up the bordem of sitting on a trainer.
This year i’ve gone more structured and am using trainerroad which apart from getting a coach seems th ebest current solution for structured trainer. I’m on second week base and have learnt so much in just over a week. Things i’ve read in books and online about trianing with power now make much more sense. At two weeks in difficult to say on fitness imporvements you really do need to dedicate the time 6 hours x 12 weeks to really start to see results and the build from their. So far I’ve actually found the endurance rides hardest mentally and physically. Even though i ride alot i generally ride at tempo riding at zone 2 edurance is actually rather hard because i haven’t really ever used those muscle cells. It is a little boring but the text guidance is great and music gets me through.
I haven’t used the android app as it’s doesn’t have all the features yet so i use a pc with an ant+ it reads power from both my power meter and the trainer and then controls the resistance.
fukawitribe
Agree with the comments above
Agree with the comments above about enjoying indoor work – it definitely can be fun – but would like to chip in on the endurance side. Proper time-crunched/HIT routines can most certainly improve your endurance fitness – you don’t need long rides to help with that as such. What longer outdoor rides will do is train your body to cope with actually dealing with the length of time endurance efforts require e.g. saddle suitability and bike position/comfort, fueling strategies, concentration and so on – and I gess also balance if you’re not on rollers inside đŸ˜‰
Next thing – fan. Vital. You really don’t need anything too fancy either – for smaller fans something like a Honeywell HT-900 circulation fan (search on eBay and Amazon) or go larger with a floor mount from ToolStation or Screwfix. You’ll still be hotter than outside but it’ll be bearable and you might be surprised how effective even a modest air flow can be.
Tacx also has apps for calibrating your trainer and training which are Android compatible. They’re basic but useful.
Lastly your Tacx should normally come with a copy of the Tacx Training Software (TTS) – I know you don’t have a PC currently but it might be worth looking at what it offers to see if it makes sense to you to buy a cheapo PC for it. TTS has virtual reality courses (crits, mountains, rolling hills, velodromes) and events using them, training workouts, online events with other riders and a good range of very high quality real life courses (RLVs) to purchase should you wish. A PC that can run TTS can be picked up very cheaply and you can display on a TV, might not be your cup of tea of course but may be worth thinking about.
Enjoy.
tritecommentbot
mickcee wrote:Iam on my third turbo and have moved from cheap no brand to a smart trainer whilst doing this. think i payed 59 quid for my first one off ebayEach winter with some structutered training I have left the winter a stronger rider and not as fat. Its can be boring just riding and listening to music or working your way through a box set so i need motivation.
i used to just watch Youtube for turbo routines, like GCN but descovered Sufferfest and Trainerroad before Zwift.
The Tour of Sufferlandria is a great aim to do on the turbo. Check it out and worth the hot sweaty painful rides in your paincave!!
Or Knighthood if you’re super hardcore!
How fit do you need to be to pull that off. Seems Godly to me..
