- This topic has 7 replies, 7 voices, and was last updated 10 years ago by .
Hi folks of the forum,
I’m hoping for some advice after my LBS failed to solve a problem I’ve been having with a new bike.
I bought a Whyte Suffolk 105 at the end of August for commuting into work. I’ve been impressed with everything about the bike except the very slack gear changes.
Basically, when I click the lever to shift up, it can take several seconds before the gear actually shifts. This is causing me some problems when pulling away from lights and junctions as I end up pedalling at excessive cadence when I pull way, then all of a sudden ‘clunking’ into the next gear when I’m not expecting it, and subsequently slowing down because the gear shift interrupts my pedalling.
As a result, I’ve taken to avoiding shifting down when I come to a stop, but this just means I end up pulling away just as slowly as in the scenario above, due to being in a high gear.
I took the bike to my LBS at the weekend, but it came back with a clean bill of health (the cables are apparently the correct length) and the suggestion was that the shifters were just not particularly responsive – in other words, ‘just get on with it, mate.’
Please tell me there’s something I can be doing to fix this. I’ve not experienced it on any of my other previous and current bikes.
