- This topic has 10 replies, 11 voices, and was last updated 10 years, 1 month ago by .
Been on flats for couple of weeks now and thought I’d share my observations. I was initially interested after watching a GCN video in which there was basically no power difference and not much difference elsewhere between flats and clipless. The main motivation for the flats was a niggling knee injury that’s already seen me on 165mm cranks and a higher cadence overall. I’d seen posts from a number of people claiming their knee problems had disappeared once they used flats and thought it was worth a shot.
So far it’s been a pretty good exeperience with the shortcomings only really being road surface and making sure your indexing is spot on.
I’m running a V8 style pedal and these Puma beauties. They’re like slippers for cyclists!
First thing I noticed was how loose everything felt. I literally felt like my feet were doing to fall off every pedal stroke….then I perservered and things started to feel better. I noticed that my pedal stroke was actually rubbish and very uneven but with clipless you’d not notice as much, with the flats there was nowhere to hide, you had to get a smooth style to get most out of them. Once I had that dialled in it felt loads better and the loose feeling was totally gone.
Next thing I noticed was that naturally my feet were falling in a different pattern to how I’d set the cleats up. No massively different but certainly not symmetrical like I’d had the cleats set up. I was getting fatigue in the right quads setting in before the left with the clipless and I noticed this wasn’t a problem after my first 2 hour ride on the flats. I also didn’t have any hotspot feeling on the balls of my feet either.
The next test was hills, not just inclines but fairly steep (15%+) ones. I was a bit worried I wouldn’t be able to transition from seated to standing but in the end there was no problem. I didn’t even notice the loss of ‘pull’ effect you get or imagine you get with clipless. Just downstroke after downstroke and power figures just as good as the clipless.
So what are the downsides? If you ride on terrible roads it could be a problem and I do mean pretty terrible roads. I’ve had a few feet moving a few cm here and there problems on really bad sections of road but nothing I’d class as being dangerous. The other problem I’ve had is really of my own making, not making sure my indexing was spot on. Basically if your indexing is out you’re going to get a potential for jumps and foot slips. Sort that out and no problems really.
Has it benefitted my knee? I’d say it’s helped as the soreness is now down to only one spot, where previously I was under attack from more than one pain point. I’m still working on my physio plan of core strengthening and a glute imbalance so maybe as time goes on this will get past it anyway. The other point may be that maybe I need to work on the cleat setup some more and perfectly symmetrical isn’t right for me at the moment.
The only major downside to all this is being shunned by other roadies. I’ve literally had one guy look at my pedals and tut at me!
