- This topic has 8 replies, 5 voices, and was last updated 10 years, 2 months ago by .
even nicer
even nicer
enough said
enough said
Never had to use threadlock
Never had to use threadlock on cage bolts.
Yep, blue Loctite or any
Yep, blue Loctite or any other medium-strength threadlocker is supposed to break loose via hand tools – i.e. with intent, not accumulation of random vibration. I’m not convinced its bond will be “too strong”
I’m no expert on carbon
I’m no expert on carbon frames, but I’d be very surprised if there was a risk of damage. Blue is the right strength to use on 99% of bike fittings, and it’s not that strong. Small bolts come undone easily enough, they just won’t do that on their own. If you ever have a threadlocked bolt that is stuck, the trick is apparently to use a soldering iron to heat the bolt, but I’m yet to have such a problem.
bikebot wrote:Yes. Between bolt head and cage.It makes very little difference, but if you’re a perfectionist that’s the way to do it. Threadlock is more important.
Thank you!
I have my Loctite Blue waiting to be used. In fact, that raises another question. If I am fitting them to a carbon frame, will the blue Loctite be ok or will it form too stong a bond?
Simple task, I hear you cry..
Simple task, I hear you cry…however my question is to do with the washers. Does one install them between the frame and the cage or between the bolt head and the cage?
