- This topic has 5 replies, 4 voices, and was last updated 10 years, 2 months ago by .
Hi all, just fitted a new stem to my hybrid. Just wanted to check if the gap between the steerer and top cap is acceptable? See pics below.
I’ve read there should be anything between 3-5mm between steerer and top of the stem or spacer before fitting the top cap. The first pic is less than this, almost flush. 2nd and 3rd pics after removing a spacer from bottom of steerer and adding to top of steerer before replacing top cap leaves a 6mm gap.
Are these both acceptable gaps?
