- This topic has 23 replies, 12 voices, and was last updated 9 years, 10 months ago by .
I have an Ultegra groupset and have been experiencing weird intermittent shifter failures and am wondering if anyone else has had the same thing or if people can suggest a possible cause.
The problem occurs every now and then (half a dozen times on a 120km ride last weekend). The symptom is that on my right shifter (controlling the rear cassette), shifting to a higher (i.e., smaller cog) gear sometimes becomes impossible. The shift lever can be pushed to the left and doesn’t encounter any resistance – no “click” feel when the gear change is initiated, nothing.
This happens frequently when I have been out of the seat on a climb. I’ll get to the crest of the hill and will go to change up a gear and… nothing. So I’m stuck in the low gear, spinning faster and faster as the road levels out. It doesn’t always happen after climbing, sometimes it will happen under a fairly normal cycling load on the flat. It just seems that the added power increases the likelihood of the shifter dropping out, but I don’t see how that could be. None of it makes sense to me though, so I mention it.
I don’t have a way of fixing the shifter. I’ve tried changing to an even lower gear, changing to the small front ring, getting off the bike and moving the rear derailleur around by hand. What works is just to wait – somewhere between 30 seconds and a few minutes – and the shifter returns to normal.
Last weekend I installed a brand new rear cassette, a new derailleur and a new chain (all of this for other reasons) but the problem persists. So it seems like the problem must be with the shifter, but what could it be?
There’s one thing I’ve done which I’m told I shouldn’t have: occasionally spray some WD40 into the shifters. Apparently this can cause a residue build up. Maybe that’s somehow occasionaly causing the shifter to drop out?
I made a couple of videos of the shifter in its non-functioning state, which do a better job of showing what’s going wrong than all the above words: http://jon.es/other/chris1.mp4 and http://jon.es/other/chris2.mp4
Thanks for any help / suggestions!
Terry
