- This topic has 5 replies, 4 voices, and was last updated 9 years, 11 months ago by .
I’m building a Kinesis Granfondo TI disc bike.
This is my first experience of both Disc brakes and Di2 shifting. Hence a potentially silly question.
I know I can run the Di2 cables through the bottom bracket to the Junction B connector.
I assume that I can Not run the rear disc hydraulic pipe through the bottom bracket? I suppose I have to exit the downtube and go under the bottom bracket, then back into the left chainstay and out again in front of the flat mount caliper.
Is this correct?
