- This topic has 11 replies, 9 voices, and was last updated 10 years, 2 months ago by .
Seeing as my bike came with an impossibly long 130mm stem and my back was hurting I bought a spangly carbon stem at 90mm to grip my 3T bar. All is good unless I go over a jolt (common in Northamptonshire) at which point the bars move about 10 degrees downwards. By the end of a long run the drops are higher than than the hoods. The stem is torqued correctly.
What is the best thing to wrap around the bar to make it 1-2mm thicker? The answer is definitely not electrical insulation tape as that has made it worse rather than better.
All responses gratefully received.
MT
