- This topic has 4 replies, 5 voices, and was last updated 10 years, 4 months ago by .
Might be the pedal. Worth
Might be the pedal. Worth checking for any play in the pedal
How old/worn are they? I
How old/worn are they? I always get a creak when I wear out the plastic bit that says shimano. Easy enough to source and replace.
I occasionally experience
I occasionally experience squeaky cleat with my SPDs on my winter road bike. Pedals are pretty new – probably around 2-3K miles; cleats are nearly brand new.
Couple of things I’ve identified:
i) Spraying all the pedal surfaces with a little silicone spray stops the squeaking for a few rides (this is the lazy, quick-fix solution), but shoe/pedal interface can feel a bit odd (very slippy) for the first ride
ii) Much of the squeakiness comes because the angle of the cleat on the shoe is not quite right, and I am operating towards one side of the float range. If I deliberately turn my heel outwards, the squeaking stops. I need to readjust my cleats.
Replace the cleats? I had a
Replace the cleats? I had a really squeaky cleat on my commuting shoes that vanished when I replaced the pair. It’s an easy enough thing to try,
