Zipp Service Course SL70 Sizing?
  • #25971
    craig749
    Hi,
    I’m contemplating chaging my cockpit over to the Zipp Service Course SL range however I’m unsure of the handlebar sizing. I currently run 42cm Ritchey bars however the Zipp bars have a 4 degree flare. As this is the case would a Zipp 44cm be the same as a 42cm Ritchey?
    Thanks
  • #874339
    VeloUSA
    Zipp
    I stand corrected
    #874337
    jn46
     The measurement for current
     The measurement for current zipp bars is centre to centre where the hoods are. Diagram under tech specs on zipp website. If you’re ritchey bars are 42 centre to centre at the hoods, then get the zipp 42cm.
    #874335
    VeloUSA
    It’s a definite yes. Zipp
    It’s a definite yes. Zipp bars with 4 degree flare are measured from bar end to bar end, so a 44cm bar measures 42cm at the hoods.
