- This topic has 5 replies, 4 voices, and was last updated 10 years, 2 months ago by .
I’m having a bit of an issue with live segments on a Garmin edge 520, and am trying to find out if anyone else has similar issues.
The basic problem is that if I have strava live segments setup the Garmin unit takes about 5 minutes to turn on; it spends a long time on the splash screen. If I connect the unit to a computer there are a lot of .fit files in the newfiles directory, if I delete these the unit boots quickly but they come back after a sync and then the slow boot problem is back.
Garmin support have told me to format the unit, which is a short term fix as the files and slowness just come back.
Has anyone else had similar problems? Or can you use live segments on a 520 without problems?
