Check out this on-skin heart rate monitor~
  • #25891
    jeremyli
  • #873493
    Simontuck
    There’s loads of wearable
    There’s loads of wearable tech either available or on its way. HR straps are on their way out. Soon you’ll have HRM woven into your base layer. The tech is there its just a matter of becoming more affordable.
    #873491
    londoncommute
    Is this any more than a stick
    Is this any more than a stick on chest strap?  Having to continually buy tape (especially if they go bust) would be a pain.  Also, no ANT+ and the pretty small discount for an untried product doesn’t make it that appealing.
    Having said that, if it’s more accurate and doesn’t give the stupid readings that chest straps give some of us then I’ll be out to buy one…..
    #873489
    Eric D
    If you type in the ‘Subject’
    If you type in the ‘Subject’ box, it disappears!
    “Right now I’m using a Fitbit HR. Everything works fine but I’m not happy with the active heart rate. Found something on indiegogo called SenseON. You can just put this on the chest.   Any one have comments on its structures? Not really an expert on that…”
