- This topic has 4 replies, 4 voices, and was last updated 16 years, 2 months ago by .
I have R556 calipers on my single speed and when you pull the rear on it won’t spring back to the same position. The cable outers are full length as that is what it appears the top tube routed guides are designed for, but even with new cables and outer it still doesn’t seem to have enough tension in the caliper?
Anyone know if I can increase the spring tension easily? Or a.n.other solution?
Can you get cable stops for old 80’s frame top tubes so it wouldn’t be a full outer?
