- This topic has 3 replies, 3 voices, and was last updated 10 years, 6 months ago by .
I did my first FTP test of the year yesterday using the British Cycling method, yesterday…
The course I use is the old railway path from Alloa to Dunfermline – that’s about a 20km ride to the start from work (which is my warm-up) and is then a largely straight, well surfaced path with a mostly consistent slight upward incline for 17.4km, apart from one interruption (up about 5 metres to a road, slow through two cycle-slaloms and then back down) at about 6km. I generally ride an easy pace to the start (with some high-cadence and a few short lung-busting accelerations), then ride the whole path at time-trial pace, starting the 20 minute timer about 2 minutes after the road. Will that brief slow-down affect the results?
Yesterday, I had a contact lens make a break for freedom about a minute into the 20, so I had to stop to sort it out. I was only stopped for about 20 seconds, maybe less, and I reset the timer once I’d got my heartrate back up to where it had been. I recorded an average of 153bpm for the 20 minutes, and was pretty much empty when I finished (so I think I paced it correctly). Can I trust that figure?
Cheers – Adam…
