- This topic has 17 replies, 12 voices, and was last updated 9 years, 5 months ago by .
I’m looking at getting a set of the above tyres, open clinchers and most likely pairing them with Vittoria latex tubes.
Has any used or is using these? If so thoughts please.
Also does anyone have an thoughts on tyre sizes, I’ve been led to believe Vittoria are often slightly wider than quoted.
I’ve been running 23mm Gatorskins throughout winter. That being said I previously ran 25mm 4 Seasons and I preferred the thicker rubber. On this basis Im debating what size Vittoria tyres to go for. If the 23’s are going to be more likely 24’s then this might be preferable to 25’s that then end up wider than quoted. However if this idea that the tyres are wider is nonsense then I think I would go for 25mm
Clear as mud? Thought so
Any advice would be appreciated, Cheers.
