- This topic has 10 replies, 9 voices, and was last updated 16 years, 1 month ago by
timlennon.
June 17, 2010 at 3:06 pm #12410
timlennon
Hi All,
I’ve been seeing odd single-speed discussions, and am kind of intrigued.
However, I have a couple of questions:
1. I have to cycle up Wimbledon Hill at night, and a similar hill in Richmond Park. Gearing seems rather essential for these … do single-speeds come with a range of options, based on what I’m normally going to be doing with it?
2. I don’t really understand the difference between single speed and fixed wheel. I *do* know that I’m not a competent enough cyclist to have a bike where I clip in and it has no freewheel capacity …Any ideas / advice?
Cheers,
Tim.
timlennon
Looking through your
Looking through your comments, and Sheldon Brown’s site (what an excellent resource!), I obviously need to try both.However, my real concerns with fixed are:
– How do I manage the hills?
– How does it work in traffic? Although I cycle a lot, I know there’s also a much higher level of stability, etc., that I should be aiming for.Thanks for all the feedback – I’ll definitely try both, and see.
KirinChris
I’ve never quite seen the
I’ve never quite seen the point of single-speed… all the downside of fixed, and none of the upside.One of the things I like about riding a fixie is the constant pedalling – it helps to smooth out my pedal strokes and riding generally. You lose that feeling of momentum through the drivetrain with a single speed in my view.
Addmitedly I don’t have hills to worry about but I spent a year with just a fixie out here and had to keep up with a fairly fast-paced club ride every week. The slowing and speeding of a group, and riding on someone’s wheel at 40km/h was quite a challenge.
Tony Farrelly
Yes, go for it. If you’re
Yes, go for it. If you’re buying a new bike it’s likely to come with something like a 44-18 set up which should be a good all rounder, certainly if you’re used to hauling a trailer up hills, that gearing shouldn’t give you any trouble at all.I’ve been riding fixed and singlespeed bikes of one sort or another pretty much solidly since the start of the year, I’d have to say that when it comes to hills I definitely prefer riding singlespeed, it’s a lot knee friendlier for a start and signalling is easier on descents. The one geared option is probably my favourite way of riding at the moment, if only because it makes your geared bike seem really fast by comparison.
I’d give both fixed and single a go and see which you prefer.
handlebarcam
The late, great Sheldon Brown
The late, great Sheldon Brown has the definitive guide to [url=http://www.sheldonbrown.com/fixed.html]fixed gear bicycles for the road[/url] and [url=http://www.sheldonbrown.com/singlespeed.html]single-speeds[/url]. Being thrown off a fixie if you stop pedalling isn’t really an issue. But there are other downsides – scroll down that first of those pages to see some gruesome consequences of not knowing what you are doing. If single-speed with a freewheel is more your style, just make sure you get a decent freewheel, not one that will stop engaging and leave you having to push miles back home, or one that is impossible to remove without hacking it apart. But there is far less to go wrong than on a derailleur-equiped bike.timlennon
It all sounds very
It all sounds very encouraging. For added info., this is my longest route home: http://j.mp/9WXejs The GPS failed a bit, but you get the general idea.It would always have to be a second bike, because I can’t imagine pulling a trailer with two children on any kind of single speed, but since cycling is my only exercise, I do like to make the most of it.
Now I’ll see if the company gets itself organised to join the cycle to work scheme … 😀
James Warrener
Yep they are so much fun they
Yep they are so much fun they should be categorised as Class A…Have a skim through my blog on here as I have posted a couple of times about the experience.
workhard
yep, get one, huge fun and
yep, get one, huge fun and does wonders for your leg strength. Unlike some I would not want my fixed to be my only bike but I do like riding it, It isn’t better or worse than geared bikes but it sure is different. I have used the ss/freewheel side (slightly lower gear and no need to pedal all the time) to get home once since I flipped it to fixed.Fishy
I commute around Brighton
I commute around Brighton (Hilly) and regularly go on short sharp 25 mile rides around the South Downs (Hilly) on a Lemond Fillmore – Fixed gear 44 x 17 (68.3 G.I)I haven’t been beaten by a hill yet, although the hills in the South Downs are pretty short and sharp (10% incline for a couple hundred meters) To be totally honest, the bigger problem than hills is headwinds, although generally this only applies in winter.
Regarding fixed:
Definitely go for it, don’t be put off by the whole ‘can’t stop peddling’ – I got used to never stopping peddling before the leap and in 2+ years now have never once come even close to feeling like I’m about to be ejected from the bike. Equally the continuous pedal stroke (as momentum will push you pass the dead spot) does wonders for your technique
Speed wise and spin outs – 68 G.I is relatively low by fixed standards, although I find it perfect, that gives me a cruising speed of 19 ish mph at about 90-100 Rpm and the ability to burst to 23-25 (110 – 120 rpm)
Downhills are supposed to be a problem, but again on the logic that ‘no faster’ than I’d be prepared to pedal, tis fine! Got to 35MPH at 170ish RPM, and I suppose that was technically a spin out – more I just couldn’t physically go faster!
Get one
Martbo23
I commute on a Cannondale
I commute on a Cannondale Capo single speed and it is brilliant. It is geared at 48/18. I don’t really have a hilly commute although there is one shortish steep section up Cedars Road to Clapham Common. I have taken it on a loop of Richmond Park before and it is manageable bt hard work especially on the shorter steeper inclines.It can be tough when you are not feeling it and grinding away into a head wind but on the whole it rocks. I have had it for 18 months and never needed to have it serviced other than usual change of tyres, break blocks etc. When you are feeling on top form you can just wind it up and let it go and it freewheels at pace. It also feels incredibly responsive for city riding which is, of course, all about the flow.
Get one, you won’t regret it.
cat1commuter
Single speed or fixed is nice
Single speed or fixed is nice for a city bike. It simple and reliable, and if buying new you’ll get better quality components for your money.Fixed you can’t stop pedalling. Up hills it feels to me like the bicycle is helping. Down hills can be hectic; I have trouble pedalling above 120 rpm. I really like fixed, but I wouldn’t want to ride not clipped in, and my commute here in Cambridge is flat.
Single speed or fixed you only have one gear, but you can choose that gear. I have a “70 inch” gear for my 12 mile commute on my fixed gear (with drop handlebars), but prefer a “65 inch” gear (and flat handlebars) for around town, where I don’t go so fast and have to accelerate from a standstill much more frequently. Most purpose built fixed or single speed bikes will come with a 70 inch gear, with a 48 tooth chainring and 18 tooth sprocket (“48×18”) or 42×16.
A 70 inch gear single speed will give you a good workout up a steep hill!
