- This topic has 7 replies, 7 voices, and was last updated 10 years, 4 months ago by .
Help with deciding on frame size appreciated
As I’m buying online the big problem is trying to predict the best size without a test ride
Using the Canyon sizing tool, (which bases frame size on inside leg length), it recommends a small frame using my 80 – 81cm inside leg length
And actually even if I drop to 79cm it still recommends a small. Only a 78cm inside leg triggers the sizing tool to recommend an extra small frame.
Now after a lot of reading around I discovered the VCLS seat post has a maximum insertion limit that leaves around 200mm of seat post exposed.
This coupled with the 510mm set tube means a minimum top of saddle to bottom bracket length of around 700mm Looking at my MTB and Brompton I think i’ll be looking at 680 -690mm
So can anyone reassure me they have an Endurace in small and have an inside length or height similar to mine or less ?
many thanks
MC
