- This topic has 17 replies, 9 voices, and was last updated 10 years, 7 months ago by
Simon E.
March 26, 2016 at 10:04 pm #25538
MadHatter
It’s tight but I’ve never had it put in such a way that it’s not contacting the fork.
Easy enough to undo and change but jus’ thought I’d ask as I like to not touch my bike as much as possible, unless I’m riding it…
and for future reference of course..
wycombewheeler wrote:
wycombewheeler wrote:I just don’t see how hooking another bike could happen.I think it’s as much about establishing a ‘best method’. Tasks like this are always easier and done properly every time if you always do it the same way.
Unless you are an especially powerful rider doing standing starts in competition (which only applies to the rear wheel anyway) I’d err on the side of using a lower clamping force rather than one requiring a big effort to open or close. The nut should begin to grip the dropout face when the cam is a little past half way closed.
I always position it beside the fork or chain/seat stay, not against it. I also only use steel internal cam skewers. The external cam type that were on my kids’ bikes were poor and have been replaced with Shimano Deore and I wouldn’t be comfortable with the superlight type for everyday year-round use.
wycombewheeler
VeloUSA wrote:
VeloUSA wrote:I’m with guyrwood on QR lever positioning. Makes it a lot easier to unfasten and no worry about marking/rubbing the frame. When group riding it also prevents the rear lever tip hooking another bike. My rule of thumb is tighten enough so the lever leaves an indentation on your palms.
I just don’t see how hooking another bike could happen. Except if the lever was backward and the rider behind overlaps and catches it with their front wheel. No possible chance if the lever is tucked away inside the rear triangle agreed but bikes shouldn’t come that close to each other.
VeloUSA
MadHatter
Don’t mind me.. the rear
Don’t mind me.. the rear wheel wasn’t sat fully into the dropouts..
StraelGuy
They should be tight enough
They should be tight enough to not come undone on their own but not so tight it hurts your hand undoing them. That’s the basic rule of QRs.
MadHatter
To update..
To update..
I cannot even get the front undone right now to reposition it, so I’m supposing that is safe.
On examining the rear I found it to be quite easy to open, on tightening it anywhere near what the front is like it seems it is bending the stays inward and is creating so much disc rub on the brakes that the wheels do not freely revolve.
MadHatter
And that all important aero..
And that all important aero…
guyrwood wrote:
guyrwood wrote:I generally have the front one pointing backwards and the rear one midway between the seat- and chainstays.Having both pointing backwards avoids the risk of them catching on something. And if you have disc brakes, provides a bit of protection to the rotors.
MadHatter
Cheers I will sort it out
Cheers I will sort it out tomorrow when I relower my seat.
Raised it by about 1.5cm and ended up with an injury in my knee.
StraelGuy
pdw
MadHatter wrote:It requires an amount of force to open so I’m guessing it’s safe.No, unless it’s gone past the “peak” of the cam then it’s not properly closed, and vibration may cause it to gradually come undone. Once it’s past the peak, then the cam is actually forcing the lever to close and it should stay closed. On every QR I’ve come across the lever will be pointing inwards a bit when fully closed. If slackening off the nut on the other side a bit allows you to close it further, then it’s not properly closed.
Grahamd
MadHatter wrote:Safe and sound, screw the rules >_<This rule is good one to stick to. By lining up directly with the fork it limits the space available to get your fingers in to open. If you have large hands like me that is quite important…
MadHatter
Just checked it, it won’t
Just checked it, it won’t really go any closer to the fork, guess the mech has just tightened the spindle a little more than I would usually see and so there isn’t as much room for folding in the lever.
pdw
That QR doesn’t look properly
That QR doesn’t look properly closed. As you close the QR you’ll feel it get harder and then slightly easier right at the end. If you don’t get to that point, it’s not properly closed and may come undone. Usually this means that you have to put the lever in front of or behind the fork.
wycombewheeler
If its nit touching the fork
If its nit touching the fork it’s fine. Otherwise just tighten it up behind the fork. -
