- This topic has 24 replies, 18 voices, and was last updated 8 years ago by
ibr17xvii.
March 25, 2016 at 8:21 pm #25531
mikpic
Hi everyone!
I am looking to buy a Canyon Aeroad bike.
On the website, they have a size calculator. When I put my measures, it says Medium (56)
I currently ride a look 695 (54)
here are my measurements
176cm
inseam: 83
arm: 61
torso:59I am wondering if I should take a small or medium? I joined the canyon GEO
thanks for any advise! It is not easy to buy online
ibr17xvii
DoctorFish wrote:ibr17xvii wrote:I’m struggling as well!Looking at an Endurace 7.0 disc, I’m 183cm tall with an inseam of 86cm. Canyon size guide says medium but I think that’s more based on my height more than anything.
I currently ride a 58 CAAD12 but I’ve rode a 56 as well & didn’t feel uncomfortable so probably could get away with either.
Stack on the Cannondale is 584, on the medium Canyon is 587 but large is 612. Reach on the ‘dale is 399, 383 on the medium Canyon & 389 on the large. On paper I’d say the medium is closest to what I have now measurements wise
However I’ve always used 175mm cranks which is only on the large Canyon, they are 172.5 on the medium which is putting me off.
Even though the medium fits me better on paper I’m leaning towards the large as the larger stack will give me a more relaxed position which is what I want as it’s a winter bike plus it has 175mm cranks.
Should I be getting the medium as that’s the better fit or am I placing too much emphasis on not having the longer cranks?
You are the same height as me, but with perhaps slightly longer legs. I ride a medium endurace and the fit is spot on. Do you think you will notice 2.5mm difference on the cranks?
Exactly the question I’m asking myself! TBH I doubt it but never having ridden them I’m not 100% sure.
Although the medium fit looks better measurement wise I want a fairly relaxed position so maybe the greater stack would be better.
Decisions, decisions….
DoctorFish
ibr17xvii
RidesAlot
Yes, I found the website to
Yes, I found the website to be misleading about swapping part’s for better fit. I found the website to be misleading when they said they would email me when a bike was available. I found the bike to be totally amazing, though.
Canyon48
TelemarkTumalo wrote:You folks are awesome and thanks for the advice. I will trust their measuring system and go with the recommended size….. when they become available again.
I’ll post back here when I get the bike.I’ve just seen you mentioned the USA based office for Canyon, I assume you’re over in the states?
If you are over in the states, this road.cc member posted this on one of the other threads I have been chatting on.
grnbrg wrote:Keep in mind that Canyon will not swap any parts in the United States. After reading reviews I was under the assumption that I could swap the cockpit to get the correct fit, but that’s not true here. The support people made all kinds of excuses (i.e. need money to change website (!?) and finance dept won’t give it). They even admitted that the website was misleading. So many excuses, no actual service. So the bike goes back to Canyon.I have no idea whether or not Canyon do swap parts (like the integrated bar stem) over in the US, this is something you should confirm before buying anything – preferably with some sort of email proof!
TelemarkTumalo
I’ll post back here when I get the bike.AfterPeak
TelemarkTumalo wrote:Thanks Canyon48. I’ll likely go with the small. The other concerns I have are the 170 mm crankarms, the 100 mm stem length, and the 39 cm bar width that comes with the small size. I understand Canyon does not allow individualization in the parts. If I could order the 41 cm bar and the 172.5mm crankarms, I’d feel more confident. I’ll check to see if there are any Canyon Demo Days in my area. Canyon’s USA office is in Chino, CA. I’m in Bend, OR.
When the bike arrives if you find the handlebars too narrow or stem too short you just email canyon and they will send you out a replacement. When it arrives just pop the old one in the post back to them. I think you have 30days to do this. My personal experience is that the sizing was bang on but I did have to change the stem length. Handlebars I also considered changing but its a faff and actually made no different.
Beecho
TelemarkTumalo wrote:Thanks Canyon48. I’ll likely go with the small. The other concerns I have are the 170 mm crankarms, the 100 mm stem length, and the 39 cm bar width that comes with the small size. I understand Canyon does not allow individualization in the parts. If I could order the 41 cm bar and the 172.5mm crankarms, I’d feel more confident. I’ll check to see if there are any Canyon Demo Days in my area. Canyon’s USA office is in Chino, CA. I’m in Bend, OR.FYI, I’m 5ft 5” and sceptically bought a 2XS on Canyon’s sizing recommendation. It’s bang on.
TelemarkTumalo
Canyon48
TelemarkTumalo wrote:This thread is a couple of years old now. I’m in the market for a new road bike and strongly considering the Canyon Ultimate CF SLX 8.0. I’m 175 cm tall, and Canyon’s bike fit calculator results in a small size recommendation. In fact, it appears I fall right in the center of the small size recommendations based on the fit chart. It looks like a few other folks on here have debated this issue. For what it’s worth, I currently ride a 55 cm road bike with an 11 cm stem and shallow drop bar (see pic below), and a 54 cm ‘cross bike with a 9 cm stem and compact/shallow drop bar. My road bike is 11 years old and definitely stretches me out along the top tube. The ‘cross bike is a more comfortable riding position for me. I’m not interested in a slammed position. All of my racing dragons have been slain, and my hope is that the Ultimate will give me a combination of light, fast and comfortable. I realize I’m rambling here, but any input regarding sizing advice and how Canyon helps me select bar width and stem reach. The Ultimate has the integrated bar and stem. Very trick looking, but it appears that size selection will be key. Thanks and enjoy the summer riding.Hi Telemark, I hope I can help.
I’m somewhere between 178 and 180 cm, I bought myself a Canyon Ultimate CF SLX Disc 8.0 (great bike) in size Medium.
I used the Canyon size chart and it recommended I buy a small (only just though, I was between small and medium). I prefer a slightly longer stretched out position on my bike. I have quite long arms, so I like a slightly longer top tube. I have the stem totally slammed as well, which looks simply great and I really like the long and low aggressive position. (Also probably worth pointing out that I’m in my early 20’s, have good flexibility and good fitness).
I’ve also ridden my other half’s Endurace (size Small, though she doesn’t use the women-specific frame). I found that the small Endurace is far too small for me, I feel very bunched up and have an arched back (even swapping to a longer stem wouldn’t make me feel at home on the bike).
Based on the information you’ve provided; being in the middle of the small size, your CX bike feeling comfier and not interested in racing – I would suggest you buy a small Ultimate (but then change the integrated bar stem if you do want something a little racier).
I would suggest that you get a few opinions and maybe try and go to a Canyon demo day – as I mentioned the fit I look for from my Ultimate may be different from yours! However, given that you said your 54cm cross bike is more comfortable, I think it’d be right to go for the 54.3 cm Canyon Ultimate (Small).
TelemarkTumalo
prokyon
I just went through the same
I just went through the same process – 178cm in height, inseam 86cm and I also have an odd body – 48cm shoulders and 35cm arms (picture Count Dracula with longer legs). I test-rode a bunch of LBS bikes both at 54 and 56 frame sizes – most people told me that I’m in-between size at 55 and that they would recommend a smaller bike – 54 frame with longer stem and larger bars. I felt like I’m on a kid’s bike every time I rode a 54 though and was afraid to hit the front brake – too much weight was over the bars. It felt very constricting, but for racing I see their point – better to get a smaller bike which is twitchy and slammed more forward.
Onto Canyon Endurace – their size calculator kept giving me a Small and I wanted a comfortable endurance bike – their Medium Endurace has a 55.3 size frame actually, which seemed perfect for me. The reason the calculator kept giving a small is because of leg size and height – at 178cm I’m between the Small and Medium. I called Canyon and they said that getting a Medium was not unreasonable, since it has more rise to the frame.
So I got a Medium Endurace CF SL 8.0 and started fitting it; I wanted a more upright riding position so I flipped the stem up to +6 degrees. On a Small Canyon Endurace I’d have to get 130mm stem and XL 46mm handlebars (with longer reach) which would be too much for a Small – so I’m glad I got the medium. My overall reach matches a Large actually, so even on a Medium I’d have to move the seat back and get large bars (which also have more reach). I changed the seat to a MTB padded seat (Specialized Henge Comp 155), sloped to 9 degrees and I sit at the back of the seat mostly – my seat post is at 1cm mark; with stock saddle and level seat I’d probably have it at 3cm mark which is not unreasonable for a Medium.
I could get away with a Small if I was racing, but for a more comfortable ride Medium seems to fit me better. All measurements matter in the end, but looks like the frame size is moslty based on saddle height with Canyon, which looking at their website has 3cm overlap – so top 3cm on Small overlaps with bottom 3cm on Medium to give same saddle height, which means that my saddle height would be almost maxed out with stock level seat on Small (making me slammed). OK, I think I’m done giving my perspective – hope this helps!
mrchumbley
Hi mikpic
For what it’s worth, I’ve recently ordered (and returned) a Canyon Endurance AL 6.0 – their sizing tool recommended an XS frame (I’m 172cm tall/ 78cm inside leg) – but the bike was too small – knees hit the handlebars when out of the saddle – I should’ve gone up a size for the S frame.
Just to add a bit of balance – I ordered the bike in February this year, it arrived within 10 working days. Communication – stick to email, I’ve had no issues (wait times on the phone did seem excessive). Getting the bike collected for the return was no problem at all either. Sounds like I could be among the lucky few tho.
Good luck
chief-o
Hi there.
Hi there.
I went through exactly the same process some months ago in trying to woride out which canyon rate side was for me. I am between sizes so it was tough. I went for a bike fit and I also pretty much used every online bike frame geometry calculator and tool I could find l. I also measured my bike meticulously to see what was he closest. I have to say that I spent probably 60 – 80 hours going through that process and at the end…. I was still unsure of the size. I even considered travelling to Germany to try a bike but they didn’t have the model. Customer service were crap. I waited I a que for like 45 mins to be given some prerehearsd speech to all people with sizing questions.
In the end as much as I was disappointed at the time I went to my lbs and picked up a bike there. So glad I did that. They were so friendly and helpful and above all I could sit on the bike. I would certainly not buy from canyon mail order if I didn’t know exactly the size. Right now I look back and think why did I even bother. I Am super pleased with what I have now and this is partly because it fits and I have a great search vice getting it etc.
My advice is buy local. Who wants a matt black bike these days anyway. 😉DanTe
mr clipup wrote:I’m almost exactly the same size as you (height 176cm and instep 83cm).I’ve got a Canyon Endurace which is a medium, on which I have the seat post set to minimum, so I suspect I’m a small medium or a large small and probably could get away with either.
Incidently it took 5 months to get my bike (2 months late in the end) and that was last year before they changed their computer system which caused the current order meltdown!
Hope this helps!
Bearing in mind that the stack on an Aeroad in a S is 2cm lower and the reach 2cm longer than an Endurance in a small…
The Aeroad is a very tricky bike to buy online as I’ve found out.
