- This topic has 13 replies, 8 voices, and was last updated 10 years, 7 months ago by .
Recently upgraded to the TRP HY-RD cable to hydraulic disc brakes on my road bike after suffering a year with BB5/7.
I’m aware the rear brake will naturally have more lever pull required to lock the brake but it’s quite severe coming all the way to the drop. One mechanic told me that compressionless housing is simply the same with a different label on (???) and another said the improvement would be very minimal.
Does anyone here have any experience of this, from what I’ve read online e.g. http://www.cxmagazine.com/mechanical-monday-upgrade-compressionless-brake-housing this is particularly useful for mechanical discs, I don’t know enough to guess why but wonder if people here have noticed a great improvement, especially if you have HY-RD brakes.
Secondly my front brake is making a noise as though the disc isn’t completely true. The mechanic who fitted them (same as the same housing different label) didn’t call or anything to tell me the parts were untrue just went ahead and fitted them. The noise is a periodic pulsating noise on applying the front brake for lack of a better description. With the BB brakes the single piston nature tended to flex the rotor as a matter of fact. Am I correct in thinking th edual piston self adjusting nature of the HY-RD brake will mean that the warp in front rotor won’t be worsened. Limited funds for the morethanforseeable make me likely to just leave this if this is the case. The brakes perform a hundred times better than Avid’s BB.
There is some periodic pad rub on the rotors on wheeling the bike back and forth, the fitter advised me that this would sort itself out over time.
Thanks in advance for any input anyone more knowledgeable than me might have on this.
