- This topic has 4 replies, 3 voices, and was last updated 10 years, 8 months ago by .
IIRC the 11-34t is a
IIRC the 11-34t is a ‘Megarange’ cassette where there is a sizeable jump between the bottom two ratios. Means the rest of the range (2 to 8) is slightly closer together. Might be worth a try, they’re only about £10, as are the 11-32t.
11-13-15-17-20-23-26-34
11-13-15-18-21-24-28-32
This is what you want
This is what you want maybe
http://www.wiggle.co.uk/shimano-cs-hg41-8-speed-cassette/
You could mix and match cassette to give close ratios at cruising speed and a bailout gear 🙂
CXR94Di2 wrote:
CXR94Di2 wrote:Normally the last three sprockets come as a cluster. What are you trying to achieve? Complete cs6800 cassette are not too expensive
On an eight speed the cluster is made with plastic spacers. you can take them apart to change around the sprockets to suit your riding.
Just trying to make an emergency gear for going up hill. Single ring up front.
I have a few cassette but no 32 teeth sprocket of 34 teeth.
