- This topic has 6 replies, 5 voices, and was last updated 10 years, 9 months ago by .
Whilst installing new tyres I happened to be reading the warning sheet that came with my Continental GP4000S II clincher tires. I will be mounting them on tubless compatible Clinchers rims. Giant aero pslr 0 ones. I usually discard this sheet and just mount the tires. But as this is new bike I wanted to read!
Basically it warns against using latex or lightweight butyl tubes and recommends using rim tape even if there are no spoke holes drilled in the rim bed. Continental claims the rim strip acts an insulating layer and helps to keep the inner tube cool. I am not an engineer but am thinking this is overkill and unnecessary. Any advice grateful as I have installed with no rim tape and used latex tubes everything they said not to!! but as the rim is tubeless compatible there were no holes will I be ok.
