- This topic has 17 replies, 16 voices, and was last updated 10 years, 7 months ago by .
I just noticed this on the KMC website regarding maintenance of your chain:
- Do not use acidic or alkali based detergents (such as rust cleaners), these can damage the chain and may cause breakage.
- Do not dip your chain in (aggressive) degreasers – they remove the remaining grease from the chain’s bearings, and may cause cracks. They are also bad for our environment.
- If the chain is really dirty and difficult to clean, besides using a brush for the inside, try putting some solvent on a cloth and use it to clean the chain’s exterior.
- Try to avoid a so-called ‘chain washing machine’ in combination with solvent. This will instantly ruin your chain.
- Some lubricant brands advise you to completely degrease the chain, KMC does not recommend this.
The full details can be found here:
http://www.kmcchain.eu/MAINTENANCE
This says use some light soapy water if required and some solvent on a cloth to clean the exterior of the chain. This seems to go against everything I have been doing to clean my chain and suggests that all the marketing products for cleaning your chain could actually be bad for it. Do I throw away my chain washing machine?
